Create Address Locator (Geocoding) |
Release 9.2
Last modified March 30, 2008 |
Print all topics in : "Tools" |
Creates an address locator
Usage tips
Address locators can be created in the same workspace of the reference data or any other workspace you specified.
The role of a reference dataset defines the role that it plays as reference data for the address locator. The address locator styles provided with ArcGIS use the following values to describe the roles of reference datasets:
Custom locator styles or locator styles provided by third parties may define different roles for reference data feature classes and tables. Refer to their documentation for information on the roles that they define for reference datasets.
The following environment settings affect this tool: Configuration keyword, workspace, and scratch workspace.
Composite address locators cannot be created using this tool.
Command line syntax
An overview of the Command Line window
CreateAddressLocator_geocoding <in_address_locator_style> <Reference Data {Role};Reference Data {Role}...> <in_field_map> <out_address_locator> {Enter the command line parameter expression here. For example, the parameter name is data_type, but the parameter expression is POINT|LINE|POLY - type POINT|LINE|POLY here - without the brackets. If there is no expression, just leave this field as is, or blank}
| Parameter | Explanation | Data Type |
| <in_address_locator_style> |
The address locator style on which to base the new address locator. When you specify an ArcSDE address locator style, the output address locator must be stored in the same ArcSDE database. You must also fully qualify an ArcSDE locator style with its workspace, as shown in the example below. |
Address Locator Style |
| <Reference Data {Role};Reference Data {Role}...> |
The reference data feature classes and tables to be used by the address locator, along with their roles.
Custom locator styles or locator styles provided by third parties may define a different set of roles for reference datasets. |
(Table View String; Table View String;...) |
| <in_field_map> |
The mapping of reference data fields used by the address locator style to fields in the reference datasets. Each field mapping in this parameter is in the format:
<locator field alias> <dataset field name> where <locator field alias> is the alias name for the reference data field used by the address locator, and <dataset field name> is the name of the field in the reference dataset. If you choose not to map an optional reference data field used by the address locator style to a field in a reference dataset, specify that there is no mapping by using "<None>" in place of a field name, as shown in the example below. To determine the alias name for a reference data field used by a locator style, open the Create Address Locator tool, and choose the locator style. The name that appears in the Field Name column of the Field Map control is the field's alias name. |
Field Info |
| <out_address_locator> |
The address locator to create. If you choose an ArcSDE address locator style, you must store the locator in the same ArcSDE database. You must also fully qualify the output address locator with its workspace, as shown in the example below. |
Address Locator |
| {Enter the command line parameter expression here. For example, the parameter name is data_type, but the parameter expression is POINT|LINE|POLY - type POINT|LINE|POLY here - without the brackets. If there is no expression, just leave this field as is, or blank} |
The configuration keyword that determines the storage parameters of the table in a Relational Database Management System (RDBMS) - ArcSDE only. |
String |
Workspace "D:\Workspace\Madison" CreateAddressLocator "US Streets" "MadisonStreets.shp 'Primary table'" "'House From Left' L_F_ADD;'House To Left' L_T_ADD;'House From Right' R_F_ADD;'House To Right' R_T_ADD;'Prefix Direction' PREFIX;'Prefix Type' PRE_TYPE;'Street Name' NAME;'Street Type' TYPE;'Suffix Direction' SUFFIX" "Madison Streets" Workspace "D:\Workspace\Madison\Madison.mdb" CreateAddressLocator "US Streets" "MadisonStreetNetwork 'Primary table'" "'House From Left' LEFT_FROM_ADDR;'House To Left' LEFT_TO_ADDR;'House From Right' RIGHT_FROM_ADDR;'House To Right' RIGHT_TO_ADDR;'Prefix Direction' PREFIX;'Prefix Type' PRE_TYPE;'Street Name' NAME;'Street Type' TYPE;'Suffix Direction' SUFFIX" "D:\Workspace\Madison\Madison.mdb\Madison Streets" Workspace "D:\Workspace\Madison\Madison.gdb" CreateAddressLocator "US Streets" "MadisonStreetNetwork 'Primary table'" "'House From Left' LEFT_FROM_ADDR;'House To Left' LEFT_TO_ADDR;'House From Right' RIGHT_FROM_ADDR;'House To Right' RIGHT_TO_ADDR;'Prefix Direction' PREFIX;'Prefix Type' PRE_TYPE;'Street Name' NAME;'Street Type' TYPE;'Suffix Direction' SUFFIX" "D:\Workspace\Madison\Madison.gdb\Madison Streets" Workspace "Database Connections\mendota.geoprocessing.sde" CreateAddressLocator "Database Connections\mendota.geoprocessing.sde\Address Locator Styles\SDE.US Streets (A)" "Madison.SDE.STREET_NETWORK 'Primary table';Madison.sde.ALT_STREETNAME 'Alternate Name table'" "'Primary table:House From Left' Madison.SDE.STREET_NETWORK:LEFT_FROM_ADDR;'Primary table:House To Left' Madison.SDE.STREET_NETWORK:LEFT_TO_ADDR;'Primary table:House From Right' Madison.SDE.STREET_NETWORK:RIGHT_FROM_ADDR;'Primary table:House To Right' Madison.SDE.STREET_NETWORK:RIGHT_TO_ADDR;'Primary table:Prefix Direction' <None>;'Primary table:Prefix Type' <None>;'Primary table:Street Name' Madison.SDE.STREET_NETWORK:STREET_NAME;'Primary table:Street Type' Madison.SDE.STREET_NETWORK:STREET_TYPE;'Primary table:Suffix Direction' Madison.SDE.STREET_NETWORK:SUFFIX;'Primary table:Join ID' Madison.SDE.STREET_NETWORK:JOINID;'Alternate Name table:Prefix Direction' Madison.sde.ALT_STREETNAME:PREFIX;'Alternate Name table:Prefix Type' Madison.sde.ALT_STREETNAME:PRE_TYPE;'Alternate Name table:Alternate Street Name' Madison.sde.ALT_STREETNAME:NAME;'Alternate Name table:Street Type' Madison.sde.ALT_STREETNAME:TYPE;'Alternate Name table:Suffix Direction' Madison.sde.ALT_STREETNAME:SUFFIX;'Alternate Name table:Join ID' Madison.sde.ALT_STREETNAME:JOINID" "Database Connections\mendota.Madison.sde\Madison Streets"
Scripting syntax
About getting started with writing geoprocessing scripts
CreateAddressLocator_geocoding (in_address_locator_style, in_reference_data, in_field_map, out_address_locator, config_keyword)
| in_address_locator_style (Required) |
| in_reference_data (Required) |
| in_field_map (Required) |
Field Info |
| out_address_locator (Required) |
Address Locator |
| config_keyword (Optional) |
String |
# Example 1:
# Create a US Streets address locator using a street centerline shapefile as reference data.
# The new address locator will be created in the folder that contains the shapefile.
import arcgisscripting
GP = arcgisscripting.create()
try:
GP.Workspace = "D:\Workspace\Madison"
locator_style = "US Streets"
reference_data = "MadisonStreets.shp 'Primary table'"
reference_data_field_map = "'House From Left' L_F_ADD;'House To Left' L_T_ADD;'House From Right' R_F_ADD;'House To Right' R_T_ADD;" "'Prefix Direction' PREFIX;'Prefix Type' PRE_TYPE;'Street Name' NAME;'Street Type' TYPE;" "'Suffix Direction' SUFFIX"
output_locator = "Madison Streets"
GP.CreateAddressLocator(locator_style, reference_data, reference_data_field_map, output_locator)
except:
print GP.GetMessages(2)
# Example 2:
# Create a US Streets address locator using a street centerline feature class in a personal or file geodatabase as reference data.
# The new address locator will be created inside the same personal or file geodatabase.
try:
# Modify the following line to specify a file geodatabase workspace such as "D:\Workspace\Madison\Madison.gdb"
GP.Workspace = "D:\Workspace\Madison\Madison.mdb"
reference_data = "MadisonStreetNetwork 'Primary table'"
reference_data_field_map = "'House From Left' LEFT_FROM_ADDR;'House To Left' LEFT_TO_ADDR;'House From Right' RIGHT_FROM_ADDR;" "'House To Right' RIGHT_TO_ADDR;'Prefix Direction' PREFIX;'Prefix Type' PRE_TYPE;'Street Name' NAME;" "'Street Type' TYPE;'Suffix Direction' SUFFIX"
output_locator = "D:\Workspace\Madison\Madison.mdb\Madison Streets"
except:
# Example 3:
# Create a US Streets with Alternate Name address locator using a street centerline feature class and an alternate street name.
# table in an ArcSDE geodatabase as reference data. The new address locator will be created in the ArcSDE database.
try:
GP.Workspace = "Database Connections\mendota.Madison.sde"
locator_style = "Database Connections\\mendota.Madison.sde\\Address Locator Styles\\SDE.US Streets (A)"
reference_data = "Madison.sde.STREET_NETWORK 'Primary table';Madison.sde.ALT_STREETNAME 'Alternate Name table'"
reference_data_field_map = "'Primary table:House From Left' Madison.sde.STREET_NETWORK:LEFT_FROM_ADDR;" "'Primary table:House To Left' Madison.sde.STREET_NETWORK:LEFT_TO_ADDR;" "'Primary table:House From Right' Madison.sde.STREET_NETWORK:RIGHT_FROM_ADDR;" "'Primary table:House To Right' Madison.sde.STREET_NETWORK:RIGHT_TO_ADDR;" "'Primary table:Prefix Direction' PREFIX;" "'Primary table:Prefix Type' <None>;" "'Primary table:Street Name' Madison.sde.STREET_NETWORK:STREET_NAME;" "'Primary table:Street Type' Madison.sde.STREET_NETWORK:STREET_TYPE;" "'Primary table:Suffix Direction' Madison.sde.STREET_NETWORK:SUFFIX;" "'Alternate Name table:Prefix Direction' Madison.sde.ALT_STREETNAME:PREFIX;" "'Alternate Name table:Prefix Type' Madison.sde.ALT_STREETNAME:PRE_TYPE;" "'Alternate Name table:Alternate Street Name' Madison.sde.ALT_STREETNAME:NAME;" "'Alternate Name table:Street Type' Madison.sde.ALT_STREETNAME:TYPE;" "'Alternate Name table:Suffix Direction' Madison.sde.ALT_STREETNAME:SUFFIX;" "'Alternate Name table:Join ID' Madison.sde.ALT_STREETNAME:JOINID"
output_locator = "Database Connections\\mendota.Madison.sde\\Madison Streets"
except:
