Create Routes (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
Print all topics in : "Tools" |
Creates routes from existing lines. The input line features that share a common identifier are merged to create a single route.
Usage tips
The outputMFlag environment setting will be ignored. The Output Route Feature Class will have M (measure) values.
If the Output Route Feature Class will be written to a geodatabase, an appropriate M Tolerance, M Resolution, and M Domain should be set.
The unique values in the Route Identifier Field are written to Output Route Feature Class.
Use Make Feature Layer or Make Query Table to effectively reduce the number of lines that will be used to create routes.
Use a Measure Factor to convert between route measure units. For example, to convert from feet to miles, use a factor of 0.00018939394.
Use a Measure Offset in applications where the start measure of each route needs to be a value other than 0.
The Ignore spatial gaps parameter is not used when the TWO_FIELDS Measure Source has been specified. This is because measure values are dictated by the From-Measure Field and To-Measure Field values.
When the LENGTH or ONE_FIELD Measure Source option is used, the Coordinate Priority is determined by placing the minimum bounding rectangle around the input features that will be merged to create one route.
When the TWO_FIELDS Measure Source option is used, it is not necessary to specify a coordinate priority because measure direction is implied by the values in the From-Measure Field and the To-Measure Field.
An attribute index on the route identifier field speeds up the dynamic segmentation process. If you will be using the Output Route Feature class for dynamic segmentation, it is recommended that you choose to have an attribute index created.
If any features are rejected by the Create Routes process, a text file is created in the temporary file path to store information about those features. For example, C:\Documents and Settings\patrickb\Local Settings\Temp\Create_Output0.txt (where 'Create_Output' is the name of the Output Route Feature Class).
The following environments affect this tool: configKeyword, extent, MTolerance, MResolution, MDomain, outputCoordinateSystem, outputZFlag, scratchWorkspace, spatialGrid1, spatialGrid2, spatialGrid3, workspace, XYDomain, and ZDomain.
Command line syntax
An overview of the Command Line window
CreateRoutes_lr <in_line_features> <route_id_field> <out_feature_class> <LENGTH | ONE_FIELD | TWO_FIELDS> {from_measure_field} {to_measure_field} {UPPER_LEFT | LOWER_LEFT | UPPER_RIGHT | LOWER_RIGHT} {measure_factor} {measure_offset} {IGNORE | NO_IGNORE} {INDEX | NO_INDEX}
| Parameter | Explanation | Data Type |
| <in_line_features> |
The features from which routes will be created. |
Feature Layer |
| <route_id_field> |
The field containing values that uniquely identify each route. |
Field |
| <out_feature_class> |
The feature class to be created. It can be a shapefile or a geodatabase feature class. |
Feature Class |
| <LENGTH | ONE_FIELD | TWO_FIELDS> |
Specifies how route measures will be obtained.
String |
| {from_measure_field} |
A field containing measure values. This field must be numeric and is required when the measure source is ONE_FIELD or TWO_FIELDS. |
Field |
| {to_measure_field} |
A field containing measure values. This field must be numeric and is required when the measure source is TWO_FIELDS. |
Field |
| {UPPER_LEFT | LOWER_LEFT | UPPER_RIGHT | LOWER_RIGHT} |
The position from which measures will be accumulated for each output route. This parameter is ignored when the measure source is TWO_FIELDS.
String |
| {measure_factor} |
A value multiplied by the measure length of each input line before they are merged to create route measures. The default is 1. |
Double |
| {measure_offset} |
A value added to the route measures after the input lines have been merged to create a route. The default is 0. |
Double |
| {IGNORE | NO_IGNORE} |
Specifies whether spatial gaps will be ignored when calculating the measures on disjointed routes. This parameter is applicable when the measure source is LENGTH or ONE_FIELD.
Boolean |
| {INDEX | NO_INDEX} |
Specifies whether an attribute index will be created for the route identifier field that is written to the output route feature class.
Boolean |
Workspace "C:\Data" CreateRoutes_lr base_roads.shp route1 create_output1 LENGTH # # LOWER_LEFT 0.00018939394 Workspace "C:\Data\pitt.mdb" CreateRoutes_lr roads\base_roads route1 roads\create_output2 ONE_FIELD len_mile # LOWER_LEFT Workspace "C:\Data\pitt.gdb" CreateRoutes_lr roads\base_roads route1 roads\create_output2 LENGTH # # LOWER_LEFT Workspace "Database Connections\Connection to Jerry.sde" CreateRoutes
Scripting syntax
About getting started with writing geoprocessing scripts
CreateRoutes_lr (in_line_features, route_id_field, out_feature_class, measure_source, from_measure_field, to_measure_field, coordinate_priority, measure_factor, measure_offset, ignore_gaps, build_index)
| in_line_features (Required) |
Feature Layer |
| route_id_field (Required) |
Field |
| out_feature_class (Required) |
Feature Class |
| measure_source (Required) |
String |
| from_measure_field (Optional) |
Field |
| to_measure_field (Optional) |
Field |
| coordinate_priority (Optional) |
String |
| measure_factor (Optional) |
Double |
| measure_offset (Optional) |
Double |
| ignore_gaps (Optional) |
Boolean |
| build_index (Optional) |
Boolean |
# Example 1:
# Create routes from lines. The lines are in a shapefile workspace.
# The LENGTH option will be used to set the measures, and a measure factor
# will be used to convert measure units from feet to miles.
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
gp.Workspace = "C:/Data"
in_lines = "base_roads.shp"
rid = "route1"
out_routes = "create_output1"
gp.CreateRoutes_lr(in_lines, rid, out_routes, "LENGTH", "#", "#", "LOWER_LEFT", 0.00018939394)
except:
print gp.GetMessages(2)
# Example 2:
# Create routes from lines. The lines are in a file geodatabase.
# The ONE_FIELD option will be used to set the measures.
try:
gp.Workspace = "C:/Data/pitt.gdb"
in_lines = "roads/base_roads" # base_roads exists in the roads feature dataset
rid = "route1"
m_fld = "len_mile"
out_routes = "roads/create_output2" # write the result to the roads feature dataset
gp.CreateRoutes_lr(in_lines, rid, out_routes, "ONE_FIELD", m_fld, "#", "LOWER_LEFT")
except:
# Example 3:
# Create routes from lines. The lines are in a personal geodatabase.
try:
gp.Workspace = "C:/Data/pitt.mdb"
rid = "route1"
m_fld = "len_mile"
except:
# Example 4:
# Create routes from lines. The lines are in an enterprise geodatabase.
# The TWO_FIELD option will be used to set the measures.
try:
wkspc = "Database Connections/Connection to Jerry.sde"
gp.Workspace = wkspc
in_lines = gp.QualifyTableName("base_roads", wkspc) # base_roads is a standalone feature class
rid = "route1"
fr_fld = "begmp1"
to_fld = "endmp1"
out_routes = "create_output3" # write the result to a standalone feature class
gp.CreateRoutes_lr(in_lines, rid, out_routes, "TWO_FIELDS", fr_fld, to_fld)
except:
