Locate Features Along Routes (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
Print all topics in : "Tools" |
Computes the intersection of input features (point, line, or polygon) and route features and writes the route and measure information to a new event table.
Usage tips
The output table can be a dBASE file or a geodatabase table.
The event type must be POINT when the input features are points and must be LINE when the input features are lines or polygons.
Use Make Feature Layer to effectively reduce the inputs that will be processed.
The output table can be displayed in ArcMap using Make Route Event Layer or the Add Route Events dialog box.
Learn more about how to locate features along routes.
The following environments affect this tool: configKeyword, extent, scratchWorkspace, and workspace.
Command line syntax
An overview of the Command Line window
LocateFeaturesAlongRoutes_lr <in_features> <in_routes> <route_id_field> <radius_or_tolerance> <out_table> <out_event_properties> {FIRST | ALL} {DISTANCE | NO_DISTANCE} {ZERO | NO_ZERO} {FIELDS | NO_FIELDS}
| Parameter | Explanation | Data Type |
| <in_features> |
The input point, line, or polygon features. |
Feature Layer |
| <in_routes> |
The routes with which the input features will be intersected. |
Feature Layer |
| <route_id_field> |
The field containing values that uniquely identify each route. This field can be numeric or character. |
Field |
| <radius_or_tolerance> |
If the input features are points, the search radius is a numeric value defining how far around each point a search will be done to find a target route. If the input features are lines, the search tolerance is really a cluster tolerance, which is a numeric value representing the maximum tolerated distance between the input lines and the target routes. If the input features are polygons, this parameter is ignored since no search radius is used. |
Linear unit |
| <out_table> |
The table to be created. |
Table |
| <out_event_properties> |
Parameter consisting of the route location fields and the type of events that will be written to the output event table. Route Identifier Field — The field that will contain values that indicate which route each event is along. Event Type — The type of events the output event table will contain (POINT or LINE).
From-Measure Field — A field that will contain measure values. Required when the event type is POINT or LINE. To-Measure Field — A field that will contain measure values. Required when the event type is LINE. |
Route Measure Event Properties |
| {FIRST | ALL} |
When locating points along routes, it is possible that more than one route may be within the search radius of any given point. This parameter is ignored when locating lines or polygons along routes.
Boolean |
| {DISTANCE | NO_DISTANCE} |
Specifies whether a field named DISTANCE will be added to the output event table. The values in this field are in the units of the specified search radius. This parameter is ignored when locating lines or polygons along routes.
Boolean |
| {ZERO | NO_ZERO} |
When locating polygons along routes, it is possible that events can be created where the from-measure is equal to the to-measure. This parameter is ignored when locating points or lines along routes.
Boolean |
| {FIELDS | NO_FIELDS} |
Specifies whether the output event table will contain route location fields plus all the attributes from the input features.
Boolean |
Workspace "C:\Data" LocateFeaturesAlongRoutes_lr rail_segments.shp rail_routes.shp rkey "0.5 Feet" locate_lines "rkey LINE fmp tmp" Workspace "C:\Data\Pitt.mdb" LocateFeaturesAlongRoutes_lr rail\crossings rail\routes rkey "10 Feet" locate_points "rkey POINT mp" Workspace "C:\Data\Pitt.gdb" LocateFeaturesAlongRoutes_lr rail\crossings rail\routes rkey "10 Feet" locate_points "rkey POINT mp" Workspace "Database Connections\Connection to Jerry.sde" LocateFeaturesAlongRoutes_lr gdb.counties gdb.rail_routes rkey # locate_polys "rkey LINE fmp tmp" # # NO_ZERO
Scripting syntax
About getting started with writing geoprocessing scripts
LocateFeaturesAlongRoutes_lr (in_features, in_routes, route_id_field, radius_or_tolerance, out_table, out_event_properties, route_locations, distance_field, zero_length_events, in_fields)
| in_features (Required) |
Feature Layer |
| in_routes (Required) |
Feature Layer |
| route_id_field (Required) |
Field |
| radius_or_tolerance (Required) |
Linear unit |
| out_table (Required) |
Table |
| out_event_properties (Required) |
| route_locations (Optional) |
Boolean |
| distance_field (Optional) |
Boolean |
| zero_length_events (Optional) |
Boolean |
| in_fields (Optional) |
Boolean |
# Example 1:
# Locate shapefile lines along shapefile routes.
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
gp.Workspace = "C:/Data"
feats = "rail_segments.shp"
rts = "rail_routes.shp"
rid = "rkey"
tol = "0.5 Feet"
tbl = "locate_lines"
props = "rkey LINE fmp tmp"
gp.LocateFeaturesAlongRoutes_lr(feats, rts, rid, tol, tbl, props )
except:
print gp.GetMessages(2)
# Example 2:
# Locate personal geodatabase points along file geodatabase routes.
try:
gp.Workspace = "C:/Data/Pitt.gdb"
feats = "rail/crossings" # crossings is in the rail feature dataset
rts = "rail/routes" # routes is in the rail feature dataset
rid = "rkey"
rad = "10 Feet"
tbl = "locate_points"
props = "rkey POINT mp"
gp.LocateFeaturesAlongRoutes_lr(feats, rts, rid, rad, tbl, props )
except:
# Example 3:
# Locate personal geodatabase points along personal geodatabase routes.
try:
gp.Workspace = "C:/Data/Pitt.mdb"
rid = "rkey"
rad = "10 Feet"
except:
# Example 4:
# Locate enterprise geodatabase polygons along enterprise geodatabase routes.
try:
wkspc = "Database Connections/Connection to Jerry.sde"
gp.Workspace = wkspc
feats = gp.QualifyTableName("counties", wkspc) # standalone feature class
rts = gp.QualifyTableName("rail_routes", wkspc) # standalone feature class
rid = "rkey"
tbl = "locate_polys"
gp.LocateFeaturesAlongRoutes_lr(feats, rts, rid, "#", tbl, props, "#", "#", "NO_ZERO")
except:
