Transform Route Events (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
Print all topics in : "Tools" |
Transforms the measures of events from one route reference to another and writes them to a new event table.
Usage tips
Transforming events allows you to use the events from one route reference with another route reference having different route identifiers and/or measures.
Any whole or partial event that intersects a target route is written to the new event table.
The output event type (POINT or LINE) must match the input event type.
The best results will be achieved when the source routes and the target routes closely overlay. Do not use a large cluster tolerance to try and overcome discrepancies between the source and target routes because it can lead to unexpected results.
Use Make Table View prior to Transform Route Events to effectively reduce the number of events that will be processed.
The output table can be displayed in ArcMap using Make Route Event Layer or the Add Route Events dialog box.
The following environments affect this tool: configKeyword, scratchWorkspace, and workspace.
Command line syntax
An overview of the Command Line window
TransformRouteEvents_lr <in_table> <in_event_properties> <in_routes> <route_id_field> <target_routes> <target_route_id_field> <out_table> <out_event_properties> <cluster_tolerance> {FIELDS | NO_FIELDS}
| Parameter | Explanation | Data Type |
| <in_table> |
The input event table. |
Table View |
| <in_event_properties> |
Parameter consisting of the route location fields and the type of events in the input event table. Route Identifier Field — The field containing values that indicate which route each event is along. This field can be numeric or character. Event Type — The type of events in the input event table (POINT or LINE).
From-Measure Field — A field containing measure values. This field must be numeric, and it is required when the event type is POINT or LINE. To-Measure Field — A field containing measure values. This field must be numeric, and it is required when the event type is LINE. |
Route Measure Event Properties |
| <in_routes> |
The input route features. |
Feature Layer |
| <route_id_field> |
The field containing values that uniquely identifies each input route. |
Field |
| <target_routes> |
The route features to which the input events will be transformed. |
Feature Layer |
| <target_route_id_field> |
The field containing values that uniquely identifies each target route. |
Field |
| <out_table> |
The table to be created. |
Table |
| <out_event_properties> |
Parameter consisting of the route location fields and the type of events that will be written to the output event table. Route Identifier Field — The field that will contain values that indicate which route each event is along. Event Type — The type of events the output event table will contain (POINT or LINE).
From-Measure Field — A field that will contain measure values. Required when the event type is POINT or LINE. To-Measure Field — A field that will contain measure values. Required when the event type is LINE. |
| <cluster_tolerance> |
The maximum tolerated distance between the input events and the target routes. |
Linear unit |
| {FIELDS | NO_FIELDS} |
Specifies whether the output event table will contain route location fields plus all the attributes from the input events.
Boolean |
Workspace "C:\Data" TransformRouteEvents_lr pavement.dbf "route1 LINE begin_mp end_mp" hwy.shp route1 hwy_new.shp route1 trans_out1.dbf "route1 LINE fmp tmp" "0.1 meters" Workspace "C:\Data\pitt.mdb" TransformRouteEvents_lr accident "route1 POINT measure" roads\hwy route1 roads\hwy_new route1 trans_out2 "route1 POINT mp" "0.1 meters" Workspace "C:\Data\pitt.gdb" TransformRouteEvents_lr accident "route1 POINT measure" roads\hwy route1 roads\hwy_new route1 trans_out2 "route1 POINT mp" "0.1 meters" Workspace "Database Connections\Connection to Jerry.sde" TransformRouteEvents_lr gdb.accident "route1 POINT measure" gdb.hwy route1 gdb.hwy_new route1 trans_out3 "route1 POINT mp" "0.1 meters"
Scripting syntax
About getting started with writing geoprocessing scripts
TransformRouteEvents_lr (in_table, in_event_properties, in_routes, route_id_field, target_routes, target_route_id_field, out_table, out_event_properties, cluster_tolerance, in_fields)
| in_table (Required) |
Table View |
| in_event_properties (Required) |
| in_routes (Required) |
Feature Layer |
| route_id_field (Required) |
Field |
| target_routes (Required) |
Feature Layer |
| target_route_id_field (Required) |
Field |
| out_table (Required) |
Table |
| out_event_properties (Required) |
| cluster_tolerance (Required) |
Linear unit |
| in_fields (Optional) |
Boolean |
# Example 1:
# Transform line events (input table is dBASE)
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
gp.Workspace = "C:/Data"
in_tbl = "pavement.dbf"
in_props = "route1 LINE begin_mp end_mp"
in_rt = "hwy.shp"
in_rid = "route1"
target_rt = "hwy_new.shp"
target_rid = "route1"
out_tbl = "trans_out1.dbf"
out_props = "route1 LINE fmp tmp"
tol = "0.1 meters"
gp.TransformRouteEvents_lr(in_tbl, in_props, in_rt, in_rid, target_rt, target_rid, out_tbl, out_props, tol)
except:
print gp.GetMessages(2)
# Example 2:
# Transform point events (input table is in a file geodatabase)
try:
gp.Workspace = "C:/Data/pitt.gdb"
in_tbl = "accident"
in_props = "route1 POINT measure"
in_rt = "roads/hwy" # hwy exists in the roads feature dataset
in_rid = "route1"
target_rt = "roads/hwy_new" # hwy_new exists in the roads feature dataset
out_tbl = "trans_out2"
out_props = "route1 POINT mp"
tol = "0.1 meters"
except:
# Example 3:
# Transform point events (input table is in a personal geodatabase)
try:
gp.Workspace = "C:/Data/pitt.mdb"
in_tbl = "accident"
in_rid = "route1"
tol = "0.1 meters"
except:
# Example 4:
# Transform point events (input table is in an enterprise geodatabase)
try:
wkspc = "Database Connections/Connection to Jerry.sde"
gp.Workspace = wkspc
in_tbl = gp.QualifyTableName("accident", wkspc)
in_rt = gp.QualifyTableName("hwy", wkspc)
in_rid = "route1"
target_rt = gp.QualifyTableName("hwy_new", wkspc)
out_tbl = "trans_out3"
tol = "0.1 meters"
except:
