Mean Center (Spatial Statistics) |
Release 9.2
Last modified January 9, 2009 |
Print all topics in : "Tools" |
Identifies the geographic center (or the center of concentration) for a set of features.
Learn about how Mean Center works
Illustration
Usage tips
The mean center is a point constructed from the average x and y values for the input feature centroids.
If a case field is specified, the input features are grouped according to case field values, and a mean center is calculated from the average x and y values for the centroids in each group.
The x and y values for the center features are feature attributes of the output feature class. The values are stored in the fields XCOORD and YCOORD.
For line and polygon features, geometric centroids are calculated before the central feature is identified. The geometric centroid of a feature may be located outside a feature's boundary. If centroids must be within feature boundaries, use the Features to Points (Inside option) to create centroids before performing the Mean Center operation.
Current map layers may be used to define the input feature class. When using layers, only the currently selected features are used in the Mean Center operation.
The following environment settings affect this tool: Cluster Tolerance, Extent, M Domain, Configuration Keyword, Coordinate System, Output has M Values, Output Spatial Grid, Output has Z Values, Default Z Value, Output XY Domain, and Output Z Domain.
Command line syntax
An overview of the Command Line window
MeanCenter_stats <Input_Feature_Class> <Output_Feature_Class> {Weight_Field} {Case_Field} {Dimension_Field}
| Parameter | Explanation | Data Type |
| <Input_Feature_Class> |
A feature class for which the mean center will be calculated. |
Feature Layer |
| <Output_Feature_Class> |
A point feature class that will contain the features representing the mean centers of the input feature class. |
Feature Class |
| {Weight_Field} |
The numeric field used to create a weighted mean center. |
Field |
| {Case_Field} |
Field used to group features for separate mean center calculations. The case field can be of numeric, date, or string type. |
Field |
| {Dimension_Field} |
A numeric field containing attribute values from which an average value will be calculated. |
Field |
workspace e:\project93\data MeanCenter schools.shp schoolcen.shp Teachers Group
Scripting syntax
About getting started with writing geoprocessing scripts
MeanCenter_stats (Input_Feature_Class, Output_Feature_Class, Weight_Field, Case_Field, Dimension_Field)
| Input_Feature_Class (Required) |
Feature Layer |
| Output_Feature_Class (Required) |
Feature Class |
| Weight_Field (Optional) |
Field |
| Case_Field (Optional) |
Field |
| Dimension_Field (Optional) |
Field |
# Measure geographic distribution characteristics of coffee house locations weighted by the number of employees
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Local variables...
workspace = "C:/data"
input_FC = "coffee_shops.shp"
CF_output = "coffee_CF.shp"
MC_output = "coffee_MC.shp"
weight_field = "NUM_EMP"
try:
# Set workspace to avoid having to type out full path names
gp.workspace = workspace
# Process: Central Feature...
gp.CentralFeature_stats(input_FC, CF_output, "Euclidean Distance", weight_field, "#")
# Process: Mean Center...
gp.MeanCenter_stats(input_FC, MC_output, weight_field, "#", "#")
except:
# If an error occurred when running the tool, print out the error message.
print gp.GetMessages()
