FloatGrid |
Release 9.2
Last modified January 3, 2008 |
Print all topics in : "Conversion (Spatial Analyst)" |
Converts a file of binary floating-point numbers to a raster.
Usage tips
Map Algebra
The input file is an IEEE floating-point format, 32-bit signed binary file.
Two inputs are required: The binary floating-point file and an ASCII header file named <in_file>.hdr.
The ASCII file consists of header information containing a set of keywords. The file format is
NCOLS xxx
NROWS xxx
XLLCENTER xxx | XLLCORNER xxx
YLLCENTER xxx | YLLCORNER xxx
CELLSIZE xxx
NODATA_VALUE xxx
BYTEORDER <MSBFIRST | LSBFIRST | VMS_FFLOAT>
where xxx is a number and the keyword NODATA_VALUE is optional.
The NODATA_VALUE is the value in the input file that determines which cells should be assigned the value of NoData in the output raster. NoData is normally reserved for those cells whose true value is unknown.
Command line syntax
See Float to Raster
Scripting syntax
See Float to Raster
Map Algebra syntax
FloatGrid( <in_file> )
| Parameter | Explanation |
| <in_file> | The input floating-point binary file. |
floatgrid (binfile)
ArcObjects syntax
See ImportFromFloat
