An overview of commonly used tools |
Release 9.2
Last modified June 27, 2006 |
Geoprocessing is one of the most powerful components of a geographic information system (GIS). Geoprocessing allows you to define, manage, and analyze the information used to form decisions.
Geoprocessing is based on a framework of data transformation. A typical geoprocessing operation performs an operation on a dataset and produces a second dataset as the result of the operation. Geoprocessing your data within the ArcGIS environment lets you perform geoprocessing operations using many different data types and methods, andit gives you access to hundreds of geoprocessing tools.
ArcGIS has over 200 available geoprocessing tools. Many more tools are available with ArcGIS extensions. Although you many find each of these tools useful to your workflow at some time, 18 tools are the most commonly used for GIS analysis (excluding conversion tools). All of the basic and higly used tools are available with all ArcGIS licenses, and all tools are available with an ArcGIS ArcInfo license.
Geoprocessing forms a vital part of the work many companies do with a GIS. Countless geoprocessing tasks may be performed on a daily basis. Some of the most commonly used geoprocessing tools are available with any ArcGIS license. These include Append, Buffer, Dissolve, Intersect, Union, and Clip.
Append is one of the Data Management tools for manipulating feature classes.
This tool merges multiple feature classes together to create a single feature
class.
Learn more about the Append tool
Buffer is one of the Analysis tools used in calculating proximity. This tool
creates a new feature class of buffer polygons around either polygon, line, or
point features.
Learn more about the Buffer tool
Clip is one of the Analysis tools used for extracting features or parts of
features from a feature class. This tool uses a polygon boundary to cut
features and their attributes from a feature class.
Learn more about the Clip toop
Dissolve is one of the Data Management tools used for generalizing features.
This tool combines like features based on a specified attribute or attributes.
Learn more about the Dissolve
tool
Integrate is one of the Data Management tools for manipulating feature classes.
This tool compares feature classes and makes identical or coincident any lines
or vertices that are within a certain distance of one another.
Intersect is one of the Analysis tools used to perform overlay analysis on
feature classes. This tool builds a new feature class from the intersecting
features common in both feature classes.
Learn more about the Intersect tool
Union is another Analysis tool used to perform overlay analysis on feature
classes. This tool builds a new feature class by combining the features and
attributes of each feature class.
Learn more about the Union tool
The following commonly used tools are available with an ArcInfo license.
Add XY Coordinates is one of the Data Management tools for managing features
and their attributes. This tool adds the POINT_X and POINT_Y fields to the
feature's attribute table and calculates the x,y location for the fields for
labels, points, tics, or nodes.
Learn more about the Add XY Coordinates tool
Erase is one of the Analysis tools used to perform overlay analysis on feature
classes. This tool creates a feature class from those features or portions of
features outside the erase feature class.
Learn more about the Erase tool
Feature to Line, Feature to Point, and Feature to Polygon are Data Management
tools used for manipulating features. These tools create line, point, or
polygon features from other features.
Learn more about the Feature to Line tool
Learn more about the Feature to Point tool
Learn more about the Feature to Polygon tool
Identity is another Analysis tool used to perform overlay analysis on feature
classes. This tool combines the portions of features that overlap the identity
features to create a new feature class.
Learn more about the Identity tool
Near is one of the Analysis tools used in calculating proximity. This tool
computes the distance from each point in the input feature class or layer to
the nearest polyline, or point, in the near feature class or layer, within the
maximum search radius.
Learn more about the Near tool
Point Distance is another Analysis tool used in calculating proximity. This
tool computes the point-to-point distance between each point in a feature class
or layer to all points in the same or different feature class or layer, within
a specified search radius.
Learn more about the Point Distance tool
Split is one of the Analysis tools used for extracting features or parts of
features from a feature class. This tool breaks the features into multiple
features.
Learn more about the Split tool
Symmetrical Difference is one of the Analysis tools used to perform overlay
analysis on feature classes. This tool creates a feature class from those
features or portions of features that are not common to any of the other
inputs.
Learn more about the Symmetrical Difference tool
Update is another one of the Analysis tools used to perform overlay analysis on
feature classes. This tool updates the attributes and geometry of an input
feature class or layer by the Update feature class or layer that they overlap.
Learn more about the Update tool
