Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Analysis toolbox > Proximity toolset > Tools
Create Thiessen Polygons (Analysis) (ArcInfo only)
Release 9.2
Last modified January 13, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Converts input points to an output feature class of Thiessen proximal polygons.
Thiessen polygons have the unique property that each polygon contains only one input point, and any location within a polygon is closer to its associated point than to the point of any other polygon.
Illustration
Thiessen illustration
Usage tips
Command line syntax
An overview of the Command Line window
CreateThiessenPolygons_analysis <in_features> <out_feature_class> {ONLY_FID | ALL}
Parameter Explanation Data Type
<in_features>
The points for which the Thiessen polygons will be generated.
Feature Layer
<out_feature_class>
The polygon feature class that will contain the Thiessen features.
Feature Class
{ONLY_FID | ALL}
Determines which attributes from the Input Features will be transferred to the Output Feature Class.
  • ONLY_FID — Only the FID field from the Input Features will be transferred to the Output Feature Class. This is the default.
  • ALL — All the attributes from the Input Features will be transferred to the Output Feature Class.
String
Data types for geoprocessing tool parameters
Command line example
createthiessenpolygons c:\basedata\wells.shp c:\analysis\thiessen_wells.shp ALL
Scripting syntax
About getting started with writing geoprocessing scripts
CreateThiessenPolygons_analysis (in_features, out_feature_class, fields_to_copy)
in_features (Required)
Feature Layer
out_feature_class (Required)
Feature Class
fields_to_copy (Optional)
String
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "c:/basedata"
gp.toolbox = "analysis"
gp.createthiessenpolygons("wells.shp", "thiessen_wells.shp", "ONLY_FID")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
