Raster Compare (Data Management) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
Compares the properties of two rasters datasets or two raster catalogs and returns the comparison result.
Usage tips
The tool returns messages showing the comparison result.
The following environments affect this tool:current workspace, scratch workspace.
Command line syntax
An overview of the Command Line window
RasterCompare_management <in_base_raster> <in_test_raster> <Raster Dataset | GDB Raster Dataset | GDB Raster Catalog> {ignore_option;ignore_option...} {NO_CONTINUE_COMPARE | CONTINUE_COMPARE} {out_compare_file}
Parameter | Explanation | Data Type |
<in_base_raster> |
The raster dataset that will be compared to the test raster. |
Raster Layer | Raster Catalog Layer |
<in_test_raster> |
The raster dataset that will be compared to the input base raster. |
<Raster Dataset | GDB Raster Dataset | GDB Raster Catalog> |
The type of comparison.
String |
{ignore_option;ignore_option...} |
The properties specified will not be compared during comparison. |
String |
{NO_CONTINUE_COMPARE | CONTINUE_COMPARE} |
Indicates whether to compare all properties after encountering the first mismatch.
Boolean |
{out_compare_file} |
The name and path of the text file which will contain the comparison results. |
Text File |
RasterCompare_management C:\basedata\redlands.img C:\testdata\redlands.tif 'Raster Dataset' # CONTINUE_COMPARE C:\tempdata\compare.txt
Scripting syntax
About getting started with writing geoprocessing scripts
RasterCompare_management (in_base_raster, in_test_raster, compare_type, ignore_option, continue_compare, out_compare_file)
in_base_raster (Required) |
in_test_raster (Required) |
compare_type (Required) |
String |
ignore_option (Optional) |
String |
continue_compare (Optional) |
Boolean |
out_compare_file (Optional) |
Text File |
Import arcgisscripting gp=arcgisscripting.create() gp.RasterCompare ( c:\basedata\redlands.img , c:\testdata\redlands.tif , Raster Dataset , # , CONTINUE_COMPARE , c:\temp\compare.txt )
