Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Distributed Geodatabase toolset > Tools
Re-Export Unacknowledged Messages (Data Management) (ArcInfo and ArcEditor only)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Creates an output delta file containing unacknowledged replica updates from a one-way or two-way replica geodatabase
Learn more about synchronizing disconnected replicas
Usage tips
Command line syntax
An overview of the Command Line window
ReExportUnacknowledgedMessages_management <in_geodatabase> <output_delta_file> <in_replica> <ALL_UNACKNOWLEDGED | MOST_RECENT>
Parameter Explanation Data Type
<in_geodatabase>
Specifies the replica geodatabase from which to re-export the unacknowledged messages. The geodatabase may be local or remote.
Workspace | GeoDataServer|GPComposite type
<output_delta_file>
Specifies the delta file in which to re-export data changes.
File
<in_replica>
The replica from which the unacknowledgement messages will be re-exported.
String
ALL_UNACKNOWLEDGED - re-exports all changes for which there has been no acknowledgement message received.
MOST_RECENT - re-rexports only those changes since the last set of exported changes was sent.
String
Data types for geoprocessing tool parameters
Command line example
ReExportUnacknowledgedMessages Countries.mdb d:\delta.mdb MyReplica1 ALL_UNACKNOWLEDGED
Scripting syntax
About getting started with writing geoprocessing scripts
ReExportUnacknowledgedMessages_management (in_geodatabase, output_delta_file, in_replica, in_export_option)
in_geodatabase (Required)
output_delta_file (Required)
File
in_replica (Required)
String
in_export_option (Required)
String
Script example
# Create the Geoprocessor object
import arcgisscripting, sys, scripting, os
gp = arcgisscripting.create()
# Set the necessary product code
gp.SetProduct("ArcInfo")
# Load required toolboxes...
gp.AddToolbox("Data Management Tools.tbx")
# Process: Re-Export Unacknowledged Messages...
gp.ReExportUnacknowledgedMessages_management("Countries.mdb", "d:\delta.mdb", "MyReplica1", "ALL_UNACKNOWLEDGED")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
