Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Domains toolset > Tools
Delete Domain (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Deletes a domain from a workspace.
Usage tips
Command line syntax
An overview of the Command Line window
DeleteDomain_management <in_workspace> <domain_name>
Parameter Explanation Data Type
<in_workspace>
The geodatabase that contains the domain to be deleted.
Workspace
<domain_name>
The name of the domain to be deleted.
String
Data types for geoprocessing tool parameters
Command line example
workspace E:\arcgis\ArcTutor\BuildingaGeodatabase
DeleteDomain_management montgomery.mdb DistDiam
Scripting syntax
About getting started with writing geoprocessing scripts
DeleteDomain_management (in_workspace, domain_name)
in_workspace (Required)
Workspace
domain_name (Required)
String
Script example
# Purpose: Update an attribute domain to constrain valid|material values
# Create the Geoprocessor object
import arcgisscripting
gp = arcgisscripting.create()
try:
    #Set the workspace (to avoid having to type in the full path to the data every time)
    gp.Workspace = "E:/arcgis/ArcTutor/BuildingaGeodatabase"
    # Set variable for domain name
    domname = "Material"
    # Process: Remove the constraint from the material field
    gp.RemoveDomainFromField("Montgomery.mdb/Water/DistribMains", "MATERIAL")
    # Edit the domain values
    # Process: Remove a coded value from the domain
    gp.DeleteCodedValueFromDomain("Montgomery.mdb", domname, "ACP: Asbestos concrete")
    # Process: Create a table from the domain to edit it with ArcMap editing tools
    gp.DomainToTable("Montgomery.mdb", domname, "Montgomery.mdb/" + domname , "TYPE", "DESCRIPT")
    # Process: Delete the domain
    gp.DeleteDomain("Montgomery.mdb", domname)
    # Edit the domain table outside of geoprocessing
    # and then bring the domain back in with the TableToDomain process
except:
    # If an error occurred while running a tool print the messages
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
