Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Domains toolset > Tools
Table to Domain (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Creates or updates a coded value domain with values from a table.
Usage tips
Command line syntax
An overview of the Command Line window
TableToDomain_management <in_table> <code_field> <description_field> <in_workspace> <domain_name> <domain_description> {APPEND | REPLACE}
Parameter Explanation Data Type
<in_table>
The database table from which to derive domain values.
Table View
<code_field>
The field in the database table from which to derive domain code values.
Field
<description_field>
The field in the database table from which to derive domain description values.
Field
<in_workspace>
The workspace that contains the domain to be created or updated.
Workspace
<domain_name>
The name of the domain to be created or updated.
String
The description of the domain to be created or updated. Domain descriptions of existing domains are not updated.
String
{APPEND | REPLACE}
If the domain already exists, specifies how the domain will be updated.
  • APPEND — Appends to the domain values from the database table.
  • REPLACE — Replaces the values in the domain with values from the database table.
String
Data types for geoprocessing tool parameters
Command line example
workspace E:\arcgis\ArcTutor\BuildingaGeodatabase
TableToDomain_management diameter.dbf code descript montgomery.mdb diameters "Valid|diameters"
Scripting syntax
About getting started with writing geoprocessing scripts
TableToDomain_management (in_table, code_field, description_field, in_workspace, domain_name, domain_description, update_option)
in_table (Required)
Table View
code_field (Required)
Field
description_field (Required)
Field
in_workspace (Required)
Workspace
domain_name (Required)
String
domain_description (Required)
String
update_option (Optional)
String
Script example
# Purpose: Update an attribute domain to constrain valid|material values
# Create the Geoprocessor object
import arcgisscripting
gp = arcgisscripting.create()
try:
    # Set the workspace (to avoid having to type in the full path to the data every time)
    gp.Workspace = "E:/arcgis/ArcTutor/BuildingaGeodatabase"
    # Process: Create a domain from an existing table
    gp.TableToDomain("diameter.dbf", "code", "descript", "Montgomery.mdb", "diameters", "Valid|diameters")
except:
    # If an error occurred while running a tool print the messages
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
