Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Feature Class toolset > Tools
Create Fishnet (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Creates a fishnet of rectangular cells.
Learn more about how Create Fishnet works
Usage tips
Command line syntax
An overview of the Command Line window
CreateFishnet_management <out_feature_class> <origin_coord> <y_axis_coord> <cell_width> <cell_height> <number_rows> <number_columns> {corner_coord} {LABELS| NO_LABELS} {template}
Parameter Explanation Data Type
<out_feature_class>
The output feature class containing the fishnet of rectangular cells.
Feature Class
<origin_coord>
The fishnet origin is the lower-left corner of the fishnet set by a X-Coordinate and Y-Coordinate.
Point
<y_axis_coord>
The y-axis coordinate is a point on the positive y-axis from the origin point and is used to orient the fishnet.
Point
<cell_width>
The cell size width refers to the size of the cells in the x-coordinate position.
Double
<cell_height>
The cell size height refers to the size of the cells in the y-coordinate direction.
Double
<number_rows>
The number of rows used with the cell size to determine the size of the fishnet.
Long
<number_columns>
The number of columns used with the cell size to determine the size of the fishnet.
Long
{corner_coord}
The opposite corner of the fishnet is the upper-right corner of the fishnet set by a X-Coordinate and Y-Coordinate.
Point
{LABELS| NO_LABELS}
Specify whether or not a point feature class will be created containing label points at the center of each fishnet cell. Labels are generated by default.
  • LABELS
  • NO_LABELS
Boolean
{template}
Specify the extent of the fishnet. The extent can be entered by specifying the coordinates or using a template dataset.
  • Left — XMin value
  • Right — XMax value
  • Bottom — YMin value
  • Top — YMax value
Data types for geoprocessing tool parameters
Command line example
CreateFishnet_management C:\WorkSpace\fishnet.shp'1037.262115 4145.810156' '1037.262115 4155.810156' 0 0 10 10 '19273.615444 18471.179674' LABELS '1037.262115 4145.810156 19273.615444 18471.179674'
Scripting syntax
About getting started with writing geoprocessing scripts
CreateFishnet_management (out_feature_class, origin_coord, y_axis_coord, cell_width, cell_height, number_rows, number_columns, corner_coord, labels, template)
out_feature_class (Required)
Feature Class
origin_coord (Required)
Point
y_axis_coord (Required)
Point
cell_width (Required)
Double
cell_height (Required)
Double
number_rows (Required)
Long
number_columns (Required)
Long
corner_coord (Optional)
Point
labels (Optional)
  • LABELS
  • NO_LABELS
Boolean
template (Optional)
  • Left — XMin value
  • Top — YMax value
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.CreateFishnet_management("C:/Workspace/fishnet.shp", "0 0", "0 2", 1, 1, 2, 3, "#", "NO_LABELS")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
