Simplify Building (Data Management) (ArcInfo only) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
Simplifies the boundary or footprint of building polygons while maintaining their essential shape and size.
Learn more about how Simplify Building works
Illustration
Usage tips
The output feature class will carry all the input fields.
The output feature class will contain two new fields: BLD_STATUS and BLD_GROUP. The BLD_STATUS records the following simplification status:
If the option to Check for spatial conflicts is checked or the CHECK_CONFLICTS option is used, the tool will detect spatial conflicts and add another new field, SimBldFlag, to store conflict flags: a value of 0 for no conflict and 1 for conflict.
The following environment settings affect this tool: XY tolerance, Extent, M domain, Coordinate system, Output has M values, Output has Z values, Default Z value, Output XY domain, workspace, and scratch workspace.
Command line syntax
An overview of the Command Line window
SimplifyBuilding_management <in_features> <out_feature_class> <simplification_tolerance> {minimum_area} {NO_CHECK | CHECK_CONFLICTS}
Parameter | Explanation | Data Type |
<in_features> |
The building polygons to be simplified. |
Feature Layer |
<out_feature_class> |
The output feature class to be created. |
Feature Class |
<simplification_tolerance> |
Sets the tolerance for building simplification. A tolerance must be specified, and it must be greater than zero. You can specify a preferred unit; the default is the feature unit. |
Linear unit |
{minimum_area} |
Sets the minimum area for a simplified building to be retained in feature units. The default value is zero, that is, to keep all buildings. You can specify a preferred unit; the default is the feature unit. |
Areal unit |
{NO_CHECK | CHECK_CONFLICTS} |
Specifies whether or not to check for potential conflicts, that is, overlapping or touching, among buildings.
Boolean |
simplifybuilding c:\workspace.mdb\bldgs c:\workspace.mdb\new_bldgs 10 0 CHECK_CONFLICT
Scripting syntax
About getting started with writing geoprocessing scripts
SimplifyBuilding_management (in_features, out_feature_class, simplification_tolerance, minimum_area, conflict_option)
in_features (Required) |
Feature Layer |
out_feature_class (Required) |
Feature Class |
simplification_tolerance (Required) |
Linear unit |
minimum_area (Optional) |
Areal unit |
conflict_option (Optional) |
Boolean |
import arcgisscripting gp = arcgisscripting.create() gp.workspace = "c:/Workspace" gp.toolbox = "management" gp.simplifybuilding( "bldgs", "new_bldgs", "10", "100")
