Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Projections and Transformations toolset > Tools
Create Custom Geographic Transformation (Data Management)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Creates a transformation method for converting data between two geographic coordinate systems or datums. The output of this tool can be used as a transformation method for any tool with a parameter that requires such a method.
Usage tips
Command line syntax
An overview of the Command Line window
CreateCustomGeoTransformation_management <geot_name> <in_coor_system> <out_coor_system> <custom_geot>
Parameter Explanation Data Type
<geot_name>
Name of the transformation method. All custom geographic transformation files are saved with a *.gtf extension and stored in the users Documents and Settings folder: ...\\Documents and Settings\<user>\Application Data\ESRI\ArcToolbox\CustomTransformations.
String
<in_coor_system>
Specify the starting geographic coordinate system.
Coordinate System
<out_coor_system>
Specify the final geographic coordinate system.
Coordinate System
<custom_geot>
Specify an existing transformation method from the drop-down list that will be used to transform the data from the input geographic coordinate system to the output geographic coordinate system. Once selected you may customize the methods values.
String
Data types for geoprocessing tool parameters
Command line example
CreateCustomGeoTransformation MyCustomGT1 GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]] GEOGCS['GCS_Abidjan_1987',DATUM['D_Abidjan_1987',SPHEROID['Clarke_1880_RGS',6378249.145,293.465]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]] GEOGTRAN[METHOD['Molodensky'],PARAMETER['X_Axis_Translation',232332.0],PARAMETER['Y_Axis_Translation',2323.0],PARAMETER['Z_Axis_Translation',2323.0]]
Scripting syntax
About getting started with writing geoprocessing scripts
CreateCustomGeoTransformation_management (geot_name, in_coor_system, out_coor_system, custom_geot)
geot_name (Required)
String
in_coor_system (Required)
Coordinate System
out_coor_system (Required)
Coordinate System
custom_geot (Required)
String
Script example
# Create the Geoprocessor Object
import arcgisscripting
gp = arcgisscripting.create()
# Set the Toolbox
GP.toolbox = "management"
# Set two spatial reference variables
InputGCS = "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"
OutputGCS = "GEOGCS['GCS_Abidjan_1987',DATUM['D_Abidjan_1987',SPHEROID['Clarke_1880_RGS',6378249.145,293.465]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"
# Customize the transformation method
CustomGT = "GEOGTRAN[METHOD['Molodensky'],PARAMETER['X_Axis_Translation',232332.0],PARAMETER['Y_Axis_Translation',2323.0],PARAMETER['Z_Axis_Translation',2323.0]]"
# Run tool in a try and except
try:
    GP.CreateCustomGeoTransformation("MyCustomGT1", InputGCS, OutputGCS, CustomGT)
except:
    print GP.GetMessages(2)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
