Build Pyramids (Data Management) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
Builds raster pyramids for a raster dataset.
Illustration
Usage tips
Building pyramids for raster datasets will help improve the display speed.
You only need to build pyramids once per dataset, then the pyramids can be accessed every time you display that raster dataset.
The following environment settings affect this tool: current workspace and pyramid (the pyramid level and resampling method do not apply to rasters in GRID, IMG, or TIFF formats).
Command line syntax
An overview of the Command Line window
BuildPyramids_management <in_raster_dataset>
Parameter | Explanation | Data Type |
<in_raster_dataset> |
The input raster dataset. |
Raster Dataset |
BuildPyramids_management D:\images\OverviewImage.img
Scripting syntax
About getting started with writing geoprocessing scripts
BuildPyramids_management (in_raster_dataset)
in_raster_dataset (Required) |
Raster Dataset |
# Create the geoprocessing object import arcgisscripting gp = arcgisscripting.create() gp.workspace = "c:/redlands_data" gp.BuildPyramids_management("redlands1.tif")
