Analyze (Data Management) (ArcInfo and ArcEditor only) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
Updates relational database management system (RDBMS) statistics of business tables, feature tables, and delta tables along with the statistics of those tables' indexes
Usage tips
After data loading, deleting, updating, and compressing operations, it is important to update RDBMS statistics in Oracle, SQL Server, DB2, or Informix databases.
The Analyze function updates the statistics of business tables, feature tables, raster tables, added tables, and deleted tables, along with the statistics on those tables' indexes.
The Components to Analyze parameter's Add Value button is used only in ModelBuilder. In ModelBuilder, where the preceding tool has not been run, or its derived data does not exist, the Components to Analyze parameter may not be populated with values. The Add Value button allows you to add expected value(s) so you can complete the Analyze dialog and continue to build your model.
The environment settings do not have an effect on this tool.
Command line syntax
An overview of the Command Line window
Analyze_management <in_dataset> <BUSINESS | FEATURE | RASTER | ADDS | DELETES>
Parameter | Explanation | Data Type |
<in_dataset> |
The table or feature class to be analyzed. |
Layer | Table View | Dataset |
<BUSINESS | FEATURE | RASTER | ADDS | DELETES> |
The component type to be analyzed.
The Add Value button, which is used only in ModelBuilder, allows you to add expected value(s) so you can complete the dialog and continue to build your model. |
String |
workspace "Database Connections\Oracle_SDE.sde" Analyze oraspatial.accident BUSINESS
Scripting syntax
About getting started with writing geoprocessing scripts
Analyze_management (in_dataset, components)
in_dataset (Required) |
components (Required) |
String |
# Purpose: Analyze a database table after data loading # Create the Geoprocessor object import arcgisscripting gp = arcgisscripting.create() try: # Set the workspace (to avoid having to type in the full path to the data every time) gp.Workspace = "Database Connections/Oracle_SDE.sde" # Process: Update business rules statistics of a table gp.Analyze("oraspatial.accident", "BUSINESS") except # If an error occurred while running a tool print the messages print gp.GetMessages()
