Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Topology toolset > Tools
Set Cluster Tolerance (Data Management) (ArcInfo and ArcEditor only)
Release 9.2
Last modified November 29, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Alters the cluster tolerance for the Input Topology. The cluster tolerance is used when validating the topology.
Usage tips
Command line syntax
An overview of the Command Line window
SetClusterTolerance_management <in_topology> <cluster_tolerance>
Parameter Explanation Data Type
<in_topology>
The topology for which you want to change the cluster tolerance.
Topology
<cluster_tolerance>
The minimum distance between vertices in the topology. Vertices that fall within the cluster tolerance will be snapped together during the validate topology process. If you enter a value of zero, the default or minimum cluster tolerance will be applied to the topology.
Double
Data types for geoprocessing tool parameters
Command line example
SetClusterTolerance D:\Calgary\Trans.mdb\Streets\Street_Topo 0.00015
Scripting syntax
About getting started with writing geoprocessing scripts
SetClusterTolerance_management (in_topology, cluster_tolerance)
in_topology (Required)
Topology
cluster_tolerance (Required)
Double
Script example
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
