Post Version (Data Management) (ArcInfo and ArcEditor only) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
Posting is the process of applying the current edit session to the reconciled target version during version geodatabase editing. Before a version can be posted, it must be reconciled with a target version and all conflicts must be resolved.
Usage tips
Posting synchronizes the edit version with the reconciled version and saves the data.
Posting can't be undone since you are applying changes to a version that you are not currently editing.
If the reconciled version is modified between reconciling and posting, you will be notified to reconcile again before posting.
The following environment settings affect this tool: workspace, scratch workspace, and output CONFIG keyword.
Command line syntax
An overview of the Command Line window
PostVersion_management <in_workspace> <version_name>
Parameter | Explanation | Data Type |
<in_workspace> |
The ArcSDE geodatabase containing the edit version to be posted. The default is to use the workspace defined in the environment. |
Workspace |
<version_name> |
Name of the edit version to be posted to the target version. |
String |
PostVersion_management "Database Connections\Connection to workspace.sde" housing
Scripting syntax
About getting started with writing geoprocessing scripts
PostVersion_management (in_workspace, version_name)
in_workspace (Required) |
Workspace |
version_name (Required) |
String |
import arcgisscripting gp = arcgisscripting.create() gp.postversion( "Database Connections\Connection to workspace.sde", "housing")
