Create File GDB (Data Management) |
Release 9.2
Last modified November 29, 2010 |
![]() ![]() ![]() Print all topics in : "Tools" |
Creates a file geodatabase, stored as a series of folders in a file system.
Usage tips
Each dataset can scale up to 1 TB in size.
Designed to be edited by a single user and do not support geodatabase versioning.
Works across operating systems.
Uses a very efficient data structure that is optimized for performance and storage. File geodatabases use about 1/3 of the feature geometry storage required by shapefiles.
Also includes a read-only compression option that allows users to create a read-only, highly compressed, and optimized geodatabase.
Recommended over personal geodatabases.
The following environment settings affect this tool: workspace, scratch workspace, Extent, M Domain, Configuration Keyword, Coordinate System, Output has M Values, Output Spatial Grid, Output has Z Values, Default Z Value, Output XY Domain, and Output Z Domain.
Command line syntax
An overview of the Command Line window
CreateFileGDB_management <out_folder_path> <out_name>
Parameter | Explanation | Data Type |
<out_folder_path> |
The location where the new file geodatabase will be created. |
Folder |
<out_name> |
The name of the file geodatabase to be created. |
String |
Scripting syntax
About getting started with writing geoprocessing scripts
CreateFileGDB_management (out_folder_path, out_name)
out_folder_path (Required) |
Folder |
out_name (Required) |
String |
import arcgisscripting gp = arcgisscripting.create() gp.workspace = "h:/workspace" gp.toolbox = "management" gp.CreateFileGDB("C:/work", "housing_test.gdb")
