Geocode Addresses (Geocoding) |
Release 9.2
Last modified March 30, 2008 |
![]() ![]() ![]() Print all topics in : "Tools" |
Geocodes a table of addresses
Illustration
Usage tips
The input address table can be any format supported by ArcGIS, including INFO, dBASE, and geodatabase tables.
The output feature class can be a shapefile or geodatabase feature class.
Choose to create a dynamic geocoded feature class if you want edits in the input address table to be automatically reflected in the output feature class. This option is only valid if the input address table and output feature class are in the same geodatabase workspace. This option is invalid if you are using an ArcView licence, as relationship classes cannot be geranted with an ArcView licence.
The following environment settings affect this tool: Configuration keyword, workspace, and scratch workspace.
Command line syntax
An overview of the Command Line window
GeocodeAddresses_geocoding <in_table> <address_locator> <in_address_fields> <out_feature_class> {STATIC | DYNAMIC}
Parameter | Explanation | Data Type |
<in_table> |
The address table to geocode |
Table View |
<address_locator> |
The address locator to use to geocode the address table |
Address Locator |
<in_address_fields> |
The mapping of input address fields used by the address locator to fields in the address table. Each field mapping in this parameter is in the format: <input address field> <table field name>where <input address field> is the name of the input address field used by the address locator, and <table field name> is the name of the corresponding field in the address table. If you choose not to map an optional input address field used by the address locator to a field in the address table, specify that there is no mapping by using "<None>" in place of a field name, as shown in the example below. To determine the alias name for a reference data field used by a locator style, open the Create Address Locator tool and choose the locator style. The name that appears in the Field Name column of the Field Map control is the field's alias name. |
Field Info |
<out_feature_class> |
The output geocoded feature class or shapefile |
Feature Class |
{STATIC | DYNAMIC} |
Indicates whether to create a static copy of the address table inside the geocoded feature class or to create a dynamically updated geocoded feature class.
Boolean |
Workspace "D:\Workspace\Madison" GeocodeAddresses Address.dbf "Madison Streets" "Street Address" Geo_result.shp Workspace "D:\Workspace\Madison\Madison.mdb" GeocodeAddresses Address "D:\Workspace\Madison\Madison Streets" "Street Address" Geo_result STATIC Workspace "D:\Workspace\Madison\Madison.gdb" GeocodeAddresses Address "D:\Workspace\Madison\Madison Streets" "Street Address" Geo_result STATIC Workspace "Database Connections\\mendota.Madison.sde" GeocodeAddresses Madison.sde.ADDRESS "Database Connections\mendota.Madison.sde\SDE.Madison Streets" "Street Address" Database Connections\mendota.Madison.sde\Geo_result DYNAMIC Workspace "D:\Workspace\Madison" GeocodeAddresses Address.dbf "GIS Servers\\mendota\\Madison_Streets" "Street Address; Zone <None>" Geo_result.shp
Scripting syntax
About getting started with writing geoprocessing scripts
GeocodeAddresses_geocoding (in_table, address_locator, in_address_fields, out_feature_class, out_relationship_type)
in_table (Required) |
Table View |
address_locator (Required) |
Address Locator |
in_address_fields (Required) |
Field Info |
out_feature_class (Required) |
Feature Class |
out_relationship_type (Optional) |
Boolean |
# Example 1: # Geocode a DBF table of addresses to a new shapefile. import arcgisscripting GP = arcgisscripting.create() try: GP.Workspace = "D:\Workspace\Madison" address_table = "Address.dbf" locator = "Madison Streets" address_field_map = "Street Address" output_shapefile = "Geo_result" GP.GeocodeAddresses(address_table, locator, address_field_map, output_shapefile) except: print GP.GetMessages(2) # Example 2: # Geocode a personal or file geodatabase table of addresses to a new feature class in the same geodatabase. # Create a static copy of the input address table in the output feature class. import arcgisscripting GP = arcgisscripting.create() try: # Modify the following line to specify a file geodatabase workspace such as "D:\Workspace\Madison\Madison.gdb" GP.Workspace = "D:\Workspace\Madison\Madison.mdb" address_table = "Address" locator = "D:\Workspace\Madison\Madison.mdb\Madison Streets" address_field_map = "Street Address" output_feature_class = "Geo_result" GP.GeocodeAddresses(address_table, locator, address_field_map, output_feature_class, "STATIC") except: print GP.GetMessages(2) # Example 3: # Geocode an ArcSDE table of addresses to a new feature class in the same ArcSDE database using an ArcSDE locator. # Create dynamic output so that edits to the address table are automatically reflected in the geocoded feature class. import arcgisscripting GP = arcgisscripting.create() try: GP.Workspace = "Database Connections\\mendota.Madison.sde" address_table = "Madison.SDE.Address" locator = "SDE.Madison Streets" address_field_map = "Street Address" output_feature_class = "Geo_result" GP.GeocodeAddresses(address_table, locator, address_field_map, output_feature_class, "DYNAMIC") except: print GP.GetMessages(2) # Example 4: # Geocode a DBF table of addresses to a new shapefile using an ArcGIS Server Geocode Server. # The address table does not contain zone information, so do not map a field to the Zone input address field # used by the address locator. import arcgisscripting GP = arcgisscripting.create() try: GP.Workspace = "D:\Workspace\Madison" address_table = "Address.dbf" locator = "GIS Servers\\mendota\\Madison_Streets" address_field_map = "Street Address; Zone <None>" output_shapefile = "Geo_result" GP.GeocodeAddresses(address_table, locator, address_field_map, output_shapefile) except: print GP.GetMessages(2)
