Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Linear Referencing toolbox > Tools
Create Routes (Linear Referencing)
Release 9.2
Last modified November 9, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Creates routes from existing lines. The input line features that share a common identifier are merged to create a single route.
Usage tips
Command line syntax
An overview of the Command Line window
CreateRoutes_lr <in_line_features> <route_id_field> <out_feature_class> <LENGTH | ONE_FIELD | TWO_FIELDS> {from_measure_field} {to_measure_field} {UPPER_LEFT | LOWER_LEFT | UPPER_RIGHT | LOWER_RIGHT} {measure_factor} {measure_offset} {IGNORE | NO_IGNORE} {INDEX | NO_INDEX}
Parameter Explanation Data Type
<in_line_features>
The features from which routes will be created.
Feature Layer
<route_id_field>
The field containing values that uniquely identify each route.
Field
<out_feature_class>
The feature class to be created. It can be a shapefile or a geodatabase feature class.
Feature Class
Specifies how route measures will be obtained.
  • LENGTH — The geometric length of the input features will be used to accumulate the measures. This is the default.
  • ONE_FIELD — The value stored in a single field will be used to accumulate the measures.
  • TWO_FIELDS — The values stored in both from- and to-measure fields will be used to set the measures.
String
A field containing measure values. This field must be numeric and is required when the measure source is ONE_FIELD or TWO_FIELDS.
Field
{to_measure_field}
A field containing measure values. This field must be numeric and is required when the measure source is TWO_FIELDS.
Field
The position from which measures will be accumulated for each output route. This parameter is ignored when the measure source is TWO_FIELDS.
  • UPPER_LEFT — Measures will be accumulated from the point closest to the minimum bounding rectangle's upper left corner. This is the default.
  • LOWER_LEFT — Measures will be accumulated from the point closest to the minimum bounding rectangle's lower left corner.
  • UPPER_RIGHT — Measures will be accumulated from the point closest to the minimum bounding rectangle's upper right corner.
  • LOWER_RIGHT — Measures will be accumulated from the point closest to the minimum bounding rectangle's lower right corner.
String
{measure_factor}
A value multiplied by the measure length of each input line before they are merged to create route measures. The default is 1.
Double
{measure_offset}
A value added to the route measures after the input lines have been merged to create a route. The default is 0.
Double
Specifies whether spatial gaps will be ignored when calculating the measures on disjointed routes. This parameter is applicable when the measure source is LENGTH or ONE_FIELD.
  • IGNORE — Spatial gaps will be ignored. Measure values will be continuous for disjointed routes. This is the default.
  • NO_IGNORE — Do not ignore spatial gaps. The measure values on disjointed routes will have gaps. The gap distance is calculated using the straight-line distance between the endpoints of the disjointed parts.
Boolean
{INDEX | NO_INDEX}
Specifies whether an attribute index will be created for the route identifier field that is written to the output route feature class.
  • INDEX — Create an attribute index. This is the default.
  • NO_INDEX — Do not create an attribute index.
Boolean
Data types for geoprocessing tool parameters
Command line example
Workspace "C:\Data"
CreateRoutes_lr base_roads.shp route1 create_output1 LENGTH # # LOWER_LEFT 0.00018939394
Workspace "C:\Data\pitt.mdb"
CreateRoutes_lr roads\base_roads route1 roads\create_output2 ONE_FIELD len_mile # LOWER_LEFT
Workspace "C:\Data\pitt.gdb"
CreateRoutes_lr roads\base_roads route1 roads\create_output2 LENGTH # # LOWER_LEFT
Workspace "Database Connections\Connection to Jerry.sde"
CreateRoutes
Scripting syntax
About getting started with writing geoprocessing scripts
CreateRoutes_lr (in_line_features, route_id_field, out_feature_class, measure_source, from_measure_field, to_measure_field, coordinate_priority, measure_factor, measure_offset, ignore_gaps, build_index)
in_line_features (Required)
Feature Layer
route_id_field (Required)
Field
out_feature_class (Required)
Feature Class
measure_source (Required)
String
from_measure_field (Optional)
Field
to_measure_field (Optional)
Field
coordinate_priority (Optional)
String
measure_factor (Optional)
Double
measure_offset (Optional)
Double
ignore_gaps (Optional)
Boolean
build_index (Optional)
Boolean
Script example
# Example 1:
#   Create routes from lines. The lines are in a shapefile workspace.
#   The LENGTH option will be used to set the measures, and a measure factor
#   will be used to convert measure units from feet to miles.
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
    gp.Workspace = "C:/Data"
    in_lines = "base_roads.shp"
    rid = "route1"
    out_routes = "create_output1"
    gp.CreateRoutes_lr(in_lines, rid, out_routes, "LENGTH", "#", "#", "LOWER_LEFT", 0.00018939394)
except:
    print gp.GetMessages(2)
# Example 2:
#   Create routes from lines. The lines are in a file geodatabase.
#   The ONE_FIELD option will be used to set the measures.
try:
    gp.Workspace = "C:/Data/pitt.gdb"
    in_lines = "roads/base_roads"                  # base_roads exists in the roads feature dataset
    rid = "route1"
    m_fld = "len_mile"
    out_routes = "roads/create_output2"            # write the result to the roads feature dataset
    gp.CreateRoutes_lr(in_lines, rid, out_routes, "ONE_FIELD", m_fld, "#", "LOWER_LEFT")
except:
# Example 3:
#   Create routes from lines. The lines are in a personal geodatabase.
try:
    gp.Workspace = "C:/Data/pitt.mdb"
    rid = "route1"
    m_fld = "len_mile"
except:
# Example 4:
#   Create routes from lines. The lines are in an enterprise geodatabase.
#   The TWO_FIELD option will be used to set the measures.
try:
    wkspc = "Database Connections/Connection to Jerry.sde"
    gp.Workspace = wkspc
    in_lines = gp.QualifyTableName("base_roads", wkspc)   # base_roads is a standalone feature class
    rid = "route1"
    fr_fld = "begmp1"
    to_fld = "endmp1"
    out_routes = "create_output3"                   # write the result to a standalone feature class
    gp.CreateRoutes_lr(in_lines, rid, out_routes, "TWO_FIELDS", fr_fld, to_fld)
except:
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
