Dissolve Route Events (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
![]() ![]() ![]() Print all topics in : "Tools" |
Removes redundant information from event tables or separates event tables having more than one descriptive attribute into individual tables.
Usage tips
The output table can be a dBASE file or a geodatabase table.
If the input events do not have an ObjectID field, use Make Query Table prior to Dissolve Route Events to add a virtual ObjectID field.
The output table can be displayed in ArcMap using Make Route Event Layer or the Add Route Events dialog box.
An attribute index on the route identifier field speeds up the dynamic segmentation process. If you will be using the Output Route Feature class for dynamic segmentation, it is recommended that you choose to have an attribute index created.
The following environments affect this tool: configKeyword, scratchWorkspace, and workspace.
Command line syntax
An overview of the Command Line window
DissolveRouteEvents_lr <in_events> <in_event_properties> <dissolve_field; dissolve_field...> <out_table> <out_event_properties> {DISSOLVE | CONCATENATE} {INDEX | NO_INDEX}
Parameter | Explanation | Data Type |
<in_events> |
The table whose rows will be aggregated. |
Table View |
<in_event_properties> |
Parameter consisting of the route location fields and the type of events in the input event table. Route Identifier Field — The field containing values that indicate which route each event is along. This field can be numeric or character. Event Type — The type of events in the input event table (POINT or LINE).
From-Measure Field — A field containing measure values. This field must be numeric and is required when the event type is POINT or LINE. To-Measure Field — A field containing measure values. This field must be numeric and is required when the event type is LINE. |
Route Measure Event Properties |
<dissolve_field; dissolve_field...> |
The field or fields used to aggregate rows. |
Field |
<out_table> |
The table to be created. |
Table |
<out_event_properties> |
Parameter consisting of the route location fields and the type of events that will be written to the output event table. Route Identifier Field — The field that will contain values that indicate which route each event is along. Event Type — The type of events the output event table will contain (POINT or LINE).
From-Measure Field — A field that will contain measure values. Required when the event type is POINT or LINE. To-Measure Field — A field that will contain measure values. Required when the event type is LINE. |
{DISSOLVE | CONCATENATE} |
Specifies whether the input events will be concatenated or dissolved.
Boolean |
{INDEX | NO_INDEX} |
Specifies whether an attribute index will be created for the route identifier field that is written to the output event table.
Boolean |
Workspace "D:\Data\pitt_county" DissolveRouteEvents_lr pavecond.dbf "rkey LINE fmp tmp" lanes pave_dissolve1 "rkey LINE fmp tmp" Workspace "D:\Data\pitt_county\pitt.mdb" DissolveRouteEvents_lr pavecond "rkey LINE fmp tmp" "lanes; curb" pave_dissolve2 "rkey LINE fmp tmp" CONCATENATE Workspace "D:\Data\pitt_county\pitt.gdb" DissolveRouteEvents_lr pavecond "rkey LINE fmp tmp" "lanes; curb" pave_dissolve2 "rkey LINE fmp tmp" CONCATENATE Workspace "Database Connections\Connection to Jerry.sde" DissolveRouteEvents_lr gdb.pavecond "rkey LINE fmp tmp" "lanes; curb" pave_dissolve3 "rid LINE f_meas t_meas" # NO_INDEX
Scripting syntax
About getting started with writing geoprocessing scripts
DissolveRouteEvents_lr (in_events, in_event_properties, dissolve_field, out_table, out_event_properties, dissolve_type, build_index)
in_events (Required) |
Table View |
in_event_properties (Required) |
dissolve_field (Required) |
Field |
out_table (Required) |
Table |
out_event_properties (Required) |
dissolve_type (Optional) |
Boolean |
build_index (Optional) |
Boolean |
# Example 1: # Dissolve line events based on one field (input table is dBASE). import arcgisscripting, constants gp = arcgisscripting.create() try: gp.Workspace = "D:/Data/pitt_county" in_tbl = "pavecond.dbf" in_props = "rkey LINE fmp tmp" # re-used as out event properties flds = "lanes" out_tbl = "pave_dissolve1.dbf" gp.DissolveRouteEvents_lr(in_tbl, in_props, flds, out_tbl, in_props) except: print gp.GetMessages(2) # Example 2: # Concatenate line events based on two fields (input table is file geodatabase). import arcgisscripting, constants gp = arcgisscripting.create() try: gp.Workspace = "D:/Data/pitt_county/pitt.gdb" in_tbl = "pavecond" in_props = "rkey LINE fmp tmp" # re-used as out event properties flds = "lanes; curb" out_tbl = "pave_dissolve2" gp.DissolveRouteEvents_lr(in_tbl, in_props, flds, out_tbl, in_props, "CONCATENATE") except: print gp.GetMessages(2) # Example 3: # Concatenate line events based on two fields (input table is personal geodatabase). import arcgisscripting, constants gp = arcgisscripting.create() try: gp.Workspace = "D:/Data/pitt_county/pitt.mdb" in_tbl = "pavecond" in_props = "rkey LINE fmp tmp" # re-used as out event properties flds = "lanes; curb" out_tbl = "pave_dissolve2" gp.DissolveRouteEvents_lr(in_tbl, in_props, flds, out_tbl, in_props, "CONCATENATE") except: print gp.GetMessages(2) # Example 4: # Dissolve line events based on two fields (input table is enterprise geodatabase). import arcgisscripting, constants gp = arcgisscripting.create() try: wkspc = "Database Connections/Connection to Jerry.sde" gp.Workspace = wkspc in_tbl = gp.QualifyTableName("pavecond", wkspc) in_props = "rkey LINE fmp tmp" flds = "lanes; curb" out_tbl = "pave_dissolve3" out_props = "rid LINE f_meas t_meas" gp.DissolveRouteEvents_lr(in_tbl, in_props, flds, out_tbl, out_props, "#", "NO_INDEX") except: print gp.GetMessages(2)
