Make Route Event Layer (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
![]() ![]() ![]() Print all topics in : "Tools" |
Creates a temporary feature layer using routes and route events.
When the temporary layer is used (displayed on a map, or used by another geoprocessing tool), dynamic segmentation is performed.
Usage tips
Temporary layers are stored in memory and can be used as input to other geoprocessing functions in your current ArcCatalog or ArcMap session.
In ArcMap, temporary feature layers can be added to the focus map's table of contents if you have indicated that you want to add results of geoprocessing operations to the display.
Once you exit ArcCatalog or ArcMap, temporary feature layers are removed from memory. To persist a temporary layer on disk, use Save To Layer File.
Temporary feature layers created in ArcCatalog cannot be used in ArcMap (and vice versa).
The input table can be any type of table ArcGIS supports.
Use Make Feature Layer on the routes and/or Make Table View on the events prior to Make Route Event Layer to reduce the number of routes and events that will be processed.
Not all types of tables have an ObjectID field. When such tables are used by Make Route Event Layer, the resulting layer will not be selectable and cannot be used effectively by certain geoprocessing operations. Consider using Make Query Table prior to Make Route Event Layer to add a virtual ObjectID field.
The following environments affect this tool: configKeyword, scratchWorkspace, and workspace.
Command line syntax
An overview of the Command Line window
MakeRouteEventLayer_lr <in_routes> <route_id_field> <in_table> <in_event_properties> <out_layer> {offset_field} {NO_ERROR_FIELD | ERROR_FIELD} {NO_ANGLE_FIELD | ANGLE_FIELD} {NORMAL | TANGENT} {ANGLE | COMPLEMENT} {LEFT | RIGHT} {POINT | MULTIPOINT}
Parameter | Explanation | Data Type |
<in_routes> |
The route features upon which events will be located. |
Feature Layer |
<route_id_field> |
The field containing values that uniquely identify each route. |
Field |
<in_table> |
The table whose rows will be located along routes. |
Table View |
<in_event_properties> |
Parameter consisting of the route location fields and the type of events in the input event table. Route Identifier Field — The field containing values that indicate which route each event is along. This field can be numeric or character. Event Type — The type of events in the input event table (POINT or LINE).
To-Measure Field — A field containing measure values. This field must be numeric and is required when the event type is LINE. |
Route Measure Event Properties |
<out_layer> |
The layer to be created. This layer is stored in memory, so a path is not necessary. |
Feature Layer |
{offset_field} |
The field containing values used to offset events from their underlying route. This field must be numeric. |
Field |
{NO_ERROR_FIELD | ERROR_FIELD} |
Specifies whether a field named LOC_ERROR will be added to the temporary layer that is created.
Boolean |
{NO_ANGLE_FIELD | ANGLE_FIELD} |
Specifies whether a field named LOC_ANGLE will be added to the temporary layer that is created. This parameter is only valid when the event type is POINT.
Boolean |
{NORMAL | TANGENT} |
Specifies the type of locating angle that will be calculated. This parameter is only valid if ANGLE_FIELD has been specified.
String |
{ANGLE | COMPLEMENT} |
Specifies whether the complement of the locating angle will be calculated. This parameter is only valid if ANGLE_FIELD has been specified.
Boolean |
{LEFT | RIGHT} |
Specifies the side on which the route events with a positive offset are displayed. This parameter is only valid if an offset field has been specified.
Boolean |
{POINT | MULTIPOINT} |
Specifies whether point events will be treated as point features or multipoint features.
Boolean |
Workspace D:\Data\pitt_county MakeRouteEventLayer_lr route_hwy.shp rkey accident.dbf "rkey POINT mile" accident_events # ERROR_FIELD ANGLE_FIELD Workspace D:\Data\pitt_county\pitt.mdb MakeRouteEventLayer_lr roads\hwy rkey pavecond "rkey LINE fmp tmp" pave_events # ERROR_FIELD Workspace D:\Data\pitt_county\pitt.gdb MakeRouteEventLayer_lr roads\hwy rkey pavecond "rkey LINE fmp tmp" pave_events # ERROR_FIELD Workspace "Database Connections\Connection to Jerry.sde" MakeRouteEventLayer_lr gdb.roads\gdb.hwy rkey gdb.accident "rkey POINT mile" accident_events2
Scripting syntax
About getting started with writing geoprocessing scripts
MakeRouteEventLayer_lr (in_routes, route_id_field, in_table, in_event_properties, out_layer, offset_field, add_error_field, add_angle_field, angle_type, complement_angle, offset_direction, point_event_type)
in_routes (Required) |
Feature Layer |
route_id_field (Required) |
Field |
in_table (Required) |
Table View |
in_event_properties (Required) |
out_layer (Required) |
Feature Layer |
offset_field (Optional) |
Field |
add_error_field (Optional) |
Boolean |
add_angle_field (Optional) |
Boolean |
angle_type (Optional) |
String |
complement_angle (Optional) |
Boolean |
offset_direction (Optional) |
Boolean |
point_event_type (Optional) |
Boolean |
# Example 1: # Make a POINT event layer. Routes and events are in a shapefile workspace. # An error field and an angle field are added to the new layer. The new layer can be used # by other geoprocessing functions. import arcgisscripting, constants gp = arcgisscripting.create() try: gp.Workspace = "D:/Data/pitt_county" rt = "route_hwy.shp" rid = "rkey" tbl = "accident.dbf" props = "rkey POINT mile" lyr = "accident_events" gp.MakeRouteEventLayer_lr (rt, rid, tbl, props, lyr, "#", "ERROR_FIELD", "ANGLE_FIELD") except: print gp.GetMessages(2) # Example 2: # Make a LINE event layer. Routes and events are in a file geodatabase. # An error field is added to the new layer. The new layer can be used by other # geoprocessing functions. import arcgisscripting, constants gp = arcgisscripting.create() try: gp.Workspace = "D:/Data/pitt_county/pitt.gdb" rt = "roads/hwy" # the 'hwy' feature class is in the 'roads' feature dataset rid = "rkey" tbl = "pavecond" props = "rkey LINE fmp tmp" lyr = "pave_events" gp.MakeRouteEventLayer_lr (rt, rid, tbl, props, lyr, "#", "ERROR_FIELD") except: print gp.GetMessages(2) # Example 3: # Make a LINE event layer. Routes and events are in a personal geodatabase. # An error field is added to the new layer. The new layer can be used by other # geoprocessing functions. import arcgisscripting, constants gp = arcgisscripting.create() try: gp.Workspace = "D:/Data/pitt_county/pitt.mdb" rt = "roads/hwy" # the 'hwy' feature class is in the 'roads' feature dataset rid = "rkey" tbl = "pavecond" props = "rkey LINE fmp tmp" lyr = "pave_events" gp.MakeRouteEventLayer_lr (rt, rid, tbl, props, lyr, "#", "ERROR_FIELD") except: print gp.GetMessages(2) # Example 4: # Make a POINT event layer. Routes and events are in an enterprise geodatabase. # The new layer can be used by other geoprocessing functions. import arcgisscripting, constants gp = arcgisscripting.create() try: wkspc = "Database Connections/Connection to Jerry.sde" gp.Workspace = wkspc ds = gp.QualifyTableName("roads", wkspc) # the 'roads' feature dataset fc = gp.QualifyTableName("hwy", wkspc) # the 'hwy' feature class rt = ds + "/" + fc #the 'hwy' feature class is in the 'roads' feature dataset rid = "rkey" tbl = gp.QualifyTableName("accident", wkspc) props = "rkey POINT mile" lyr = "accident_events2" gp.MakeRouteEventLayer_lr (rt, rid, tbl, props, lyr) except: print gp.GetMessages(2)
