Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Linear Referencing toolbox > Tools
Transform Route Events (Linear Referencing)
Release 9.2
Last modified November 9, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Transforms the measures of events from one route reference to another and writes them to a new event table.
Usage tips
Command line syntax
An overview of the Command Line window
TransformRouteEvents_lr <in_table> <in_event_properties> <in_routes> <route_id_field> <target_routes> <target_route_id_field> <out_table> <out_event_properties> <cluster_tolerance> {FIELDS | NO_FIELDS}
Parameter Explanation Data Type
<in_table>
The input event table.
Table View
Parameter consisting of the route location fields and the type of events in the input event table.
Route Identifier Field — The field containing values that indicate which route each event is along. This field can be numeric or character.
Event Type — The type of events in the input event table (POINT or LINE).
  • POINT — Point events occur at a precise location along a route. Only a from-measure field must be specified.
  • LINE — Line events define a portion of a route. Both from- and to-measure fields must be specified.
From-Measure Field — A field containing measure values. This field must be numeric, and it is required when the event type is POINT or LINE.
To-Measure Field — A field containing measure values. This field must be numeric, and it is required when the event type is LINE.
Route Measure Event Properties
<in_routes>
The input route features.
Feature Layer
<route_id_field>
The field containing values that uniquely identifies each input route.
Field
<target_routes>
The route features to which the input events will be transformed.
Feature Layer
The field containing values that uniquely identifies each target route.
Field
<out_table>
The table to be created.
Table
Parameter consisting of the route location fields and the type of events that will be written to the output event table.
Route Identifier Field — The field that will contain values that indicate which route each event is along.
Event Type — The type of events the output event table will contain (POINT or LINE).
From-Measure Field — A field that will contain measure values. Required when the event type is POINT or LINE.
To-Measure Field — A field that will contain measure values. Required when the event type is LINE.
<cluster_tolerance>
The maximum tolerated distance between the input events and the target routes.
Linear unit
Specifies whether the output event table will contain route location fields plus all the attributes from the input events.
  • FIELDS — The output event table will contain route location fields plus all the attributes from the input events. This is the default.
  • NO_FIELDS — The output event table will only contain route location fields plus the ObjectID field from the input events.
Boolean
Data types for geoprocessing tool parameters
Command line example
Workspace "C:\Data"
TransformRouteEvents_lr pavement.dbf "route1 LINE begin_mp end_mp" hwy.shp route1 hwy_new.shp route1 trans_out1.dbf "route1 LINE fmp tmp" "0.1 meters"
Workspace "C:\Data\pitt.mdb"
TransformRouteEvents_lr accident "route1 POINT measure" roads\hwy route1 roads\hwy_new route1 trans_out2 "route1 POINT mp" "0.1 meters"
Workspace "C:\Data\pitt.gdb"
Workspace "Database Connections\Connection to Jerry.sde"
TransformRouteEvents_lr gdb.accident "route1 POINT measure" gdb.hwy route1 gdb.hwy_new route1 trans_out3 "route1 POINT mp" "0.1 meters"
Scripting syntax
About getting started with writing geoprocessing scripts
TransformRouteEvents_lr (in_table, in_event_properties, in_routes, route_id_field, target_routes, target_route_id_field, out_table, out_event_properties, cluster_tolerance, in_fields)
in_table (Required)
Table View
in_event_properties (Required)
in_routes (Required)
Feature Layer
route_id_field (Required)
Field
target_routes (Required)
Feature Layer
target_route_id_field (Required)
Field
out_table (Required)
Table
out_event_properties (Required)
cluster_tolerance (Required)
Linear unit
in_fields (Optional)
Boolean
Script example
# Example 1:
# Transform line events (input table is dBASE)
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
    gp.Workspace = "C:/Data"
    in_tbl = "pavement.dbf"
    in_props = "route1 LINE begin_mp end_mp"
    in_rt = "hwy.shp"
    in_rid = "route1"
    target_rt = "hwy_new.shp"
    target_rid = "route1"
    out_tbl = "trans_out1.dbf"
    out_props = "route1 LINE fmp tmp"
    tol = "0.1 meters"
    gp.TransformRouteEvents_lr(in_tbl, in_props, in_rt, in_rid, target_rt, target_rid, out_tbl, out_props, tol)
except:
    print gp.GetMessages(2)
# Example 2:
#   Transform point events (input table is in a file geodatabase)
try:
    gp.Workspace = "C:/Data/pitt.gdb"
    in_tbl = "accident"
    in_props = "route1 POINT measure"
    in_rt = "roads/hwy"               # hwy exists in the roads feature dataset
    in_rid = "route1"
    target_rt = "roads/hwy_new"       # hwy_new exists in the roads feature dataset
    out_tbl = "trans_out2"
    out_props = "route1 POINT mp"
    tol = "0.1 meters"
except:
# Example 3:
#   Transform point events (input table is in a personal geodatabase)
try:
    gp.Workspace = "C:/Data/pitt.mdb"
    in_tbl = "accident"
    in_rid = "route1"
    tol = "0.1 meters"
except:
# Example 4:
#   Transform point events (input table is in an enterprise geodatabase)
try:
    wkspc = "Database Connections/Connection to Jerry.sde"
    gp.Workspace = wkspc
    in_tbl = gp.QualifyTableName("accident", wkspc)
    in_rt = gp.QualifyTableName("hwy", wkspc)
    in_rid = "route1"
    target_rt = gp.QualifyTableName("hwy_new", wkspc)
    out_tbl = "trans_out3"
    tol = "0.1 meters"
except:
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
