Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Multidimensional toolbox > Tools
Select By Dimension (Multidimension)
Release 9.2
Last modified November 9, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Updates the netCDF layer display or netCDF table view based on the dimension value.
Usage tips
Command line syntax
An overview of the Command Line window
SelectByDimension_md <in_layer_or_table> {dimension {value};dimension {value}...} {BY_VALUE | BY_INDEX}
Parameter Explanation Data Type
<in_layer_or_table>
The input netCDF raster layer, netCDF feature layer, or netCDF table view.
Raster Layer | Feature Layer | Table View
A set of dimension – value pairs used to specify a slice of a multidimensional variable.
  • dimension — A netCDF dimension.
  • {value} — A value of the dimension to specify a slice of a multidimensional variable.
(String String; String String;...)
Specifies the dimension value selection method.
  • BY_VALUE — The input value is matched with the actual dimension value.
  • BY_INDEX — The input value is matched with the position or index of a dimension value. The index is 0 based, that is, the position starts at 0.
String
Data types for geoprocessing tool parameters
Command line example
SelectByDimension rainfall_layer "time '1900-12-31 00:00:0'" BY_VALUE
Scripting syntax
About getting started with writing geoprocessing scripts
SelectByDimension_md (in_layer_or_table, dimension_values, value_selection_method)
in_layer_or_table (Required)
dimension_values (Optional)
value_selection_method (Optional)
String
Script example
# SelectByDimension.py
# Description: Updates the netCDF layer display based on the dimension value.
# Requirements: None
# Author: ESRI
# Create the Geoprocessor object
import arcgisscripting, sys, string, os
gp = arcgisscripting.create()
try:
    # Set local variables
    InNetCDFRasterLayer = "rainfall_layer"
    InDefaultValues = "time '1900-12-31 00:00:0'"
    InValueSelectionMethod = "BY_VALUE"
    # Process: SelectByDimension
    gp.SelectByDimension(InNetCDFRasterLayer, InDefaultValues, InValueSelectionMethod)
except:
    # Print error message if an error occurs
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
