Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Server toolbox > Caching toolset > Tools
Update Map Server Cache (Server)
Release 9.2
Last modified November 22, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Updates an existing Map Service cache to replace missing tiles, overwrite outdated tiles, or add new tiles in new areas or, in the case of a multi-layer cache, from additional layers.
Usage tips
Command line syntax
An overview of the Command Line window
UpdateMapServerCache_Server <server_name> <object_name> <data_frame> <layer;layer...> {constraining_extent} <scale;scale...> <RECREATE_EMPTY_TILES| RECREATE_ALL_TILES> {thread_count} {NONE | ANTIALIASING}
Parameter Explanation Data Type
<server_name>
The host name of the ArcGIS Server to use to update the cache.
String
<object_name>
The name of the Map Service to use to update the cache.
String
<data_frame>
The map frame to cache.
String
<layer;layer...>
Layers to remove from the cache.
String
Extent in the cache to update.
Extent
<scale;scale...>
A list of scale levels to update.
String
Choose a mode for updating the cache. The two modes are:
  • Recreate Empty Tiles - Only tiles that are empty (have been deleted on disk), or that are new because the cache extent has changed or because new layers have been added to a multi-layer cache, will be created. Old tiles will be left unchanged.
  • Recreate All Tiles - All tiles will be replaced and new tiles will be added if the extent has changed or if layers have been added to a multi-layer cache.
Boolean
{thread_count}
Number of Map Server instances to use while updating the cache.
Long
Choose whether to use antialiasing when rendering the tiles. If ANTIALIASING is edges of lines, borders, and text will be smoothed. There is a performance cost for this option. No benefit will be gained on raster data.
Boolean
Data types for geoprocessing tool parameters
Command line example
UpdateMapServerCache "myServer" "myMapService" "Layers" "Layer1;Layer2" "5.86 47.27 15.04 55.05" "8000000;4000000;2000000" "Recreate Empty Tiles" 2 Antialiasing
Scripting syntax
About getting started with writing geoprocessing scripts
UpdateMapServerCache_Server (server_name, object_name, data_frame, layer, constraining_extent, levels, update_mode, thread_count, antialiasing)
server_name (Required)
String
object_name (Required)
String
data_frame (Required)
String
layer (Required)
String
constraining_extent (Optional)
Extent
levels (Required)
String
update_mode (Required)
Boolean
thread_count (Optional)
Long
antialiasing (Optional)
Boolean
Script example
# Script Name: Update Fused Map Server Cache
# Description: Updates a fused map server cache
# Uncomment sys.argv[] lines to accept arguments from the command line.
# Import standard library modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Set the SOM server name
# Example: "mySOM"
server_name = "mySOM"
#server_name = sys.argv[1]
# Set the object_name
# Example: "MyServiceFolder/MyService"
object_name = "MyServiceFolder/MyService"
#object_name = sys.argv[2]
# Set the data frame
# Example: "Layers"
data_frame = "Layers"
#data_frame = sys.argv[3]
# Set the layers to cache.
# Example: "My First Layer;My Second Layer;My Third Layer"
layers = "My First Layer;My Second Layer;My Third Layer"
#layers = sys.argv[4]
# Set the extent to update in the cache.
# Example: "8 50 10 52"
constraining_extent = "8 50 10 52"
#constraining_extent = sys.argv[5]
# Set the scale levels for the cache.
# Example: "2000000;500000;250000"
scales = "2000000;500000;250000"
#scales = sys.argv[6]
# Set the update mode.
# Example: "Recreate Empty Tiles"
update_mode = "Recreate All Tiles"
#update_mode = sys.argv[7]
# Set number of instances to use while updating the cache
# Example: "3"
thread_count = "3"
#thread_count = sys.argv[8]
# Set antialiasing mode
# Example: "NONE"
antialiasing = "ANTIALIASING"
#antialiasing = sys.argv[9]
try:
    print 'Starting Cache Update'
    gp.UpdateMapServerCache(server_name, object_name, data_frame, layers, constraining_extent,  scales, update_mode, thread_count, antialiasing)
    print 'Finished Cache Update'
except:
    gp.AddMessage(gp.GetMessages(2))
    print gp.GetMessages(2)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
