Z Score Rendering (Spatial Statistics) |
Release 9.2
Last modified January 9, 2009 |
![]() ![]() ![]() Print all topics in : "Tools" |
Applies a cold-to-hot graduated color rendering to a field of z scores.
Illustration
Usage tips
The Z Renderer creates a layer file with z scores rendered in the following manner:
The Z Renderer is appropriate for rendering output from both Hot Spot Analysis and Cluster and Outlier Analysis tools.
This tool will only work on the windows operating system.
The environment settings do not affect this tool.
Command line syntax
An overview of the Command Line window
ZRenderer_stats <Input_Feature_Class> <Field_to_Render> <Output_Layer_File>
Parameter | Explanation | Data Type |
<Input_Feature_Class> |
The feature class containing a file with standardized Z scores. |
Feature Layer |
<Field_to_Render> |
The name of the field containing the z scores. |
Field |
<Output_Layer_File> |
The output layer file to store rendering information. You must include the .lyr extension as part of the file name. |
Layer File |
workspace e:\project93\data HotSpot tracts.shp AGE_65_UP tract65.shp 'Inverse Distance' 'Euclidean Distance' 0 None ZRenderer tract65.shp GiInvDst tracthot
Scripting syntax
About getting started with writing geoprocessing scripts
ZRenderer_stats (Input_Feature_Class, Field_to_Render, Output_Layer_File)
Input_Feature_Class (Required) |
Feature Layer |
Field_to_Render (Required) |
Field |
Output_Layer_File (Required) |
Layer File |
# Perform Hot Spot Analysis for assault incidents # Import system modules import arcgisscripting # Create the Geoprocessor object gp = arcgisscripting.create() # Local variables... workspace = "C:/project93/data" input = "assaults.shp" collect_output = "collect_output.shp" collect_count_field = "Count" hotspot_output = "hotspot_output.shp" hotspot_output_rendered = "hotspot_output_rendered.lyr" z_score_field_name = "GiInvDst" try: # Set the current workspace (to avoid having to specify the full path to the feature classes each time) gp.workspace = workspace # Convert assault incidents into weighted point data # Process: Collect Events... gp.CollectEvents_stats(input, collect_output) # Calculate Getis-Ord Gi* statistic # Process: Hot Spot Analysis (Getis-Ord Gi*)... gp.HotSpots_stats(collect_output, collect_count_field, hotspot_output, "Inverse Distance", "Euclidean Distance", "None", "#", "#", "#") # Render hot spot analysis # Process: Z Score Rendering... gp.ZRenderer_stats(hotspot_output, z_score_field_name, hotspot_output_rendered) except: # If an error occurred when running the tool, print out the error message. print gp.GetMessages(2)
