Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Environment Settings > General settings
XY Tolerance
Release 9.2
Last modified September 4, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "General settings"
Related Topics
NOTE: In ArcGIS 9.2, the term xy tolerance has been introduced. This term is synonymous with cluster tolerance. In certain contexts the term cluster tolerance has been replaced by the term XY Tolerance.
Specify the XY Tolerance that will be used for processing and set to the output geodataset.
Learn more about XY tolerance
Usage tips
Command line syntax
An overview of the command line window
XYTolerance <linear unit>
Parameters Explanation Datatype
<Linear unit> The minimum distance separating all feature coordinates (nodes and vertices), and the distance a coordinate can move in X or Y (or both).
You can set the value to be higher for data that has less coordinate accuracy and lower for datasets with extremely high accuracy.
The default XY tolerance is set to 0.001 meters or its equivalent in map units.
Linear Unit
Data types for geoprocessing tool parameters
Command line example
XYTolerance 0.02
Scripting syntax
An overview of scripting in geoprocessing
XYTolerance (Linear unit)
Linear unit (Required) The minimum distance separating all feature coordinates (nodes and vertices) , and the distance a coordinate can move in X or Y (or both).
Linear Unit
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "H:\\Tongass"
gp.XYTolerance = "0.02"
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
