Show Navigation | Hide Navigation
You are here:
Getting started > Introducing ArcGIS Desktop
Workspace and dataset management with ArcCatalog
Release 9.2
Last modified October 27, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Introducing ArcGIS Desktop"
Related Topics
In ArcGIS applications, you work with multiple data sources—datasets, relational databases, and file types and schemas. ArcGIS allows you to work with geographic information in many forms including relational databases, files, ArcGIS documents, and remote GIS Web services.
ArcCatalog helps you by providing an integrated and unified view of these various sources of information. The ArcCatalog application helps you organize and manage all your geographic information, such as maps, globes, datasets, models, metadata, and services. It includes tools to:
You can employ ArcCatalog to find, organize, and use GIS data as well as to document data holdings using standards-based metadata.
A GIS database administrator uses ArcCatalog to define and build geodatabases. A GIS server administrator uses ArcCatalog to administer his ArcGIS server framework.
Workspaces and geodatabases
Workspaces and geodatabases provide the primary containers to store and manage geographic information for ArcGIS.
Workspaces are directories (file folders on disk) that hold numerous GIS datasets and a series of ArcGIS documents. Workspaces can contain external datasets in many file formats as well as references to geodatabases. For example, you can work with file geodatabases, connect to ArcSDE geodatabases, and work with folders containing numerous data files—such as ESRI shapefiles and coverages, JPEG images, DXF CAD files, dBase tables, Excel spreadsheets, and GML data files.
You organize your datasets and ArcGIS documents into a series of file system folders (often referred to as ArcGIS workspaces) and in geodatabases.
Organizing datasets by workspaces and in geodatabases is useful because it provides a mechanism to:
Typical contents in a workspace can include:
A geodatabase is a collection of geographic datasets of various types used for representing features, images, tabular data, and other data types managed in either a file structure or a multiuser relational database. It is the native data source for ArcGIS and is used for editing and data automation in ArcGIS.
ArcGIS documents
In ArcGIS, you work with system documents and files such as:
ArcGIS applications use a series of documents for saving work created in ArcGIS. These documents define how maps, map elements, map layers, globes, globe elements, and geoprocessing models are managed and used within the software. For example, a map document specifies the set of map elements contained in a map along with the map layers and their display properties used to present GIS datasets. Once you create a map document, you can use it simply by selecting the document and opening it. This will launch the ArcMap application for the selected map.
Each ArcGIS document is saved as a file in a disk folder.
Some of the commonly used ArcGIS documents found in ArcGIS workspace folders
Document type How it is used Filename extension Notes
ArcMap document
Double-click to start ArcMap .mxd
A file containing a map, its layers, display information, and other elements used in ArcMap.
ArcGlobe document
Double-click to start ArcGlobe .3dd
A file containing a globe, its layers, and 3D display properties for use in ArcGlobe. Part of the 3D Analyst extension.
ArcScene document
Double-click to start ArcScene .sxd
A file containing a 3D scene, its layers, and 3D properties for use in ArcScene. Part of the 3D Analyst extension.
ArcGIS Layer file
Drag-and-drop into ArcMap, ArcGlobe, or ArcScene .lyr
A layer is a set of rules for displaying and working with datasets in ArcMap and ArcGlobe. Layer definitions include symbol assignments, classifications, labeling rules, and other map use properties.
Published Map File for ArcReader
Double-click to start ArcReader .pmf
A read-only map file created using the ArcGIS Publisher extension. Read-only maps can be used in ArcReader and ArcMap. They can also be served on the Web.
ArcGIS Style file
Open in ArcMap to assign symbols for markers, lines, fills, and text .style
A predefined set of colors, symbols, and graphical elements used for displaying and representing geographic datasets according to a mapping standard.
ArcGIS Address Locator file
Used for geocoding in ArcGIS .loc
A Locator dataset and rules used for geocoding addresses in ArcGIS. Locators are types of geodatabase datasets and can be saved independently of the geodatabase as a disk file for sharing and use
Metadata files
Used to document all information sets. Viewed and edited in ArcCatalog .xml
Metadata documents for individual file-based datasets are stored in XML files and often managed in ArcGIS workspace folders.
ArcGIS models, toolsets, and geoprocessing tools
Used in the geoprocessing framework .tbx
Collections of geoprocessing models saved using toolbox files.
Map projection file
Saved with each dataset as its coordinate system .prj
Coordinate system and map projection information for a dataset
Geoprocessing scripts Used in the geoprocessing framework .py.
aml
Python (.py) and ArcInfo Workstation AML scripts used for geoprocessing in ArcGIS
ArcCatalog
ArcCatalog provides an integrated and unified view of all the data files, databases, and ArcGIS documents available to you. ArcCatalog is also used to document and manage metadata and to define the schemas of geodatabases.
ArcCatalog provides an integrated view of geographic informtion sets used in ArcGIS
The Catalog tree
A key step in ArcGIS is to establish a connection to file folders and geodatabases that you plan to use.
Adding folder connections in ArcCatalog
Once connected, ArcCatalog helps you manage all your geographic information sets using the Catalog tree to view your disk files and database connections. The ArcCatalog user interface presents the Catalog tree in the left-hand panel. By selecting an element in the Catalog tree, you can read its various properties and views in the right-hand panel. You can edit the Catalog tree, make new connections, add new elements (such as datasets), and remove elements.
The left-hand Catalog tree panel in ArcCatalog is used to navigate between workspaces, geodatabases, and dataset contents
Some of the elements commonly shown in the Catalog tree include:
The Preview panel
You can see the geographic content of an item that is selected (and highlighted) in the Catalog tree using the Preview panel.
The preview panel in ArcCatalog
Metadata in ArcCatalog
Metadata documents can be created, edited, and viewed in ArcCatalog.
Creating and managing geodatabase schemas in ArcCatalog
Database administrators can create and manage the schemas of their geodatabases using ArcCatalog.
Adding new datasets and items to your geodatabase in ArcCatalog
Toolbars in ArcCatalog
ArcCatalog contains a number of toolbars that are used to view datasets and to perform a number of workspace and information management tasks in ArcGIS. For example, you can use the Preview panel to view your data in a map view and use the Geography toolbar to zoom and pan across of your dataset. Here is a quick review of some of the commonly used toolbars in ArcCatalog.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
