About ArcGIS Desktop extensions |
Release 9.3
Last modified December 29, 2008 |
Print all topics in : "Extensions" |
| Functions | Extension | Extended capabilities |
| Analysis | ArcGIS 3D Analyst | Three-dimensional visualization and analysis. Includes ArcGlobe and ArcScene applications. Also includes terrain data management and geoprocessing tools. |
ArcGIS Spatial Analyst | Includes a broad range of powerful raster modeling and analysis features that allow you to create, query, map, and analyze cell-based raster data. ArcGIS Spatial Analyst also allows integrated raster–vector analysis.
Adds more than 200 tools to the ArcGIS geoprocessing framework. |
ArcGIS Geostatistical Analyst | Advanced statistical tools for surface generation and for analyzing and mapping continuous datasets. Includes exploratory spatial data analysis tools providing insights about your data distribution, global and local outliers, global trends, level of spatial autocorrelation, and variation among multiple datasets. |
ArcGIS Network Analyst | Allows you to perform advanced routing and network analysis. Supports
ArcGIS Schematics | Enables generating, visualizing, and manipulating diagrams from network data coming from a geodatabase or any data that has explicit attributes showing connectivity. Allows you to
ArcGIS Tracking Analyst | Real-time and historic data display and temporal analysis.
ArcGIS Tracking Analyst includes
| Data Integration and Editing | ArcGIS Data Interoperability | Adds the ability to directly read and employ more than 60 common GIS vector data formats including many of the evolving GML specifications.
In addition, GIS data can be delivered in a variety of formats. For example, data sources, such as advanced computer-aided design (CAD) datasets with extended entity attributes, MapInfo datasets, Intergraph GeoMedia datasets, and various GML files, can be accessed, displayed, and used directly in ArcGIS. Enables delivery of GIS data to others in a variety of vector data formats (more than 50 supported formats). |
ArcScan for ArcGIS
NOTE: ArcScan capabilities are included with ArcEditor and ArcInfo but must be purchased for use with ArcView. |
Performs raster-to-vector conversion tasks on scanned documents including raster editing, raster snapping, manual raster tracing, and batch vectorization.
ArcGIS Survey Analyst | Tools used by surveyors and GIS professionals to create and maintain survey data in ArcGIS.
Includes support for editing and managing cadastral fabrics and measurement-based cadastral workflows. This support adds important new capabilities for GIS users who manage parcels and will begin to increase the accuracy levels using measurement-based cadastres. |
| Data Publishing | ArcGIS Publisher | Publish data, maps, and globes authored using ArcGIS Desktop. With ArcMap and ArcGlobe, you can author interactive maps and globes and then publish them with ArcGIS.
Publish and share them via ArcReader. |
| Cartography |
Maplex for ArcGIS
NOTE: Maplex capabilities are included with ArcInfo but must be purchased for use with ArcView and ArcEditor. |
Adds advanced label placement and conflict detection to ArcMap. Use to generate text saved with map documents and as annotation layers in the geodatabase.
Using Maplex for ArcGIS can save significant production time. |
| Extension | Audience | Extended capabilities |
| Production Line Tool Set (PLTS) | Cartographic production and mapping agencies | A comprehensive series of software applications for efficient GIS database production and maintenance as well as automated map series production using ArcGIS and the geodatabase. |
ArcGIS Business Analyst
Business and demographic applications | A suite of tools for working with high-quality demographics, consumer, lifestyle, and business data that is spatially integrated using geography. Delivered with a rich set of data content and powerful tools for working with business and demographic data. |
| Job Tracking for ArcGIS (JTX) | Data services and production workgroups | An enterprise workflow management application that provides an integration framework for the ArcGIS multiuser geodatabase environments. |
| Military Overlay Editor (MOLE) | Military and defense users | An application and API that allow you to create, display, and edit military symbology in your ArcGIS maps. |
| Military Analyst | Military and defense users | A suite of GIS tools for the defense user using ArcGIS Desktop. |
To use an extension for which you are registered or licensed, you must enable it in the Extensions dialog box for the application in which you will use it. To open the Extensions dialog box, choose the Extensions command from the Tools menu in ArcMap, ArcCatalog, ArcGlobe, or ArcScene (the application that comes with the ArcGIS 3D Analyst extension).
The Extensions dialog box lists the extensions currently installed on your system that work with the application you are using. For example, if you are using ArcCatalog, you'll only see extensions listed that work with ArcCatalog. Extensions are listed in this dialog box whether or not you have registered them or whether or not licenses are currently available for them on your License Manager.
To enable an extension, check the box next to it:
Spatial Analyst
Spatial Analyst
Spatial Analyst (Not Registered/Authorized)
Spatial Analyst (License not available)
Yes. ArcMap will let you open any map regardless of which extensions are currently available in the Extensions dialog box. However, data or functionality in the map that depends on a particular extension will not be available if no license is available for that extension. When you open a map containing data that requires an auto-enabling extension such as StreetMap, you won't be able to use that data if the required extension is unable to obtain a license. Layers referencing this data will be disabled in the ArcMap table of contents with a red exclamation mark next to them.
