Slope |
Release 9.3
Last modified September 7, 2011 |
Print all topics in : "Surface (Spatial Analyst)" |
Identifies the rate of maximum change in z-value from each cell.
Learn more about how Slope works
Illustration
OutRas = Slope(InRas1)
Slope_sa InRas1 OutRas
Usage tips
Command line and Scripting
Slope is the rate of maximum change in z-value from each cell.
The use of a z-factor is essential for correct slope calculations when the surface z units are expressed in units different from the ground x,y units.
The range of slope values in degrees is 0 to 90. For percent rise, the range is 0 for near infinity. A flat surface is 0 percent, a 45 degree surface is 100 percent, and as the surface becomes more vertical, the percent rise becomes increasingly larger.
If the center cell in the immediate neighborhood (3 x 3 window) is NoData, the output is NoData.
If any neighborhood cells are NoData, they are assigned the value of the center cell; then the slope is computed.
The following environment settings affect this tool:
Map Algebra
The surface information for calculating the slope can be expressed as raster.item for any numeric item in the value attribute table. The default item is Value.
The use of a z-factor is essential for correct slope calculations when the surface z units are expressed in units which are different from the ground x,y units.
Learn more about how to specify the input raster dataset in the Map Algebra expression of Raster Calculator.
ArcObjects
Valid input for the geoDataset to ArcObjects is a Raster, RasterDataset, RasterBand, or RasterDescriptor.
The range of values with the Degree option of slopeType is 0 to 90. The range of the PercentRise option is 0 to near infinity. A flat surface is 0 percent, a 45 degree surface is 100 percent, and as the surface becomes more vertical, the percent rise becomes increasingly larger.
The output from the ArcObjects method is a raster object.
Command line syntax
An overview of the Command Line window
Slope_sa <in_raster> <out_raster> {DEGREE | PERCENT_RISE} {z_factor}
| Parameter | Explanation | Data Type |
| <in_raster> |
Input raster. |
Composite Geodataset |
| <out_raster> |
The raster to be created. |
Raster Dataset |
| {DEGREE | PERCENT_RISE} |
Determines the measurement units (degrees or percentages) of the output slope data.
String |
| {z_factor} |
The number of ground x,y units in one surface z unit. The z-factor adjusts the units of measure for the z units when they are different from the x,y units of the input surface. The z-values of the input surface are multiplied by the z-factor when calculating the final output surface. If the x,y units and z units are in the same units of measure, the z-factor is 1. This is the default. If the x,y units and z units are in different units of measure, the z-factor must be set to the appropriate factor, or the results will be incorrect. For example, if your z units are feet and your x,y units are meters, you would use a z-factor of 0.3048 to convert your z units from feet to meters (1 foot = 0.3048 meter). |
Double |
Slope_sa C:/data/dem C:/data/slope PERCENT_RISE
Scripting syntax
About getting started with writing geoprocessing scripts
Slope_sa (in_raster, out_raster, output_measurement, z_factor)
| in_raster (Required) |
Input raster. |
| out_raster (Required) |
Raster Dataset |
| output_measurement (Optional) |
String |
| z_factor (Optional) |
Double |
# Slope_sample.py
# Description:
# Derives slope from a raster surface.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
# Set local variables
InRaster = "C:/data/dem"
OutRaster = "C:/data/slope"
InMeasurementType = "PERCENT_RISE"
# Check out ArcGIS Spatial Analyst extension license
gp.CheckOutExtension("Spatial")
# Process: Slope
gp.Slope_sa(InRaster, OutRaster, InMeasurementType)
except:
# If an error occurred while running a tool, then print the messages.
print gp.GetMessages()
Map Algebra syntax
Slope(<grid>, {DEGREE | PERCENTRISE})
| <grid> | Any valid combination of rasters, numbers, operators, and functions that produces an output raster. |
| {DEGREE | PERCENTRISE} | Keywords specifying the units in which the value of slope will be expressed.
| <z_factor> | The number of ground x,y units in one surface z unit.
The z-factor adjusts the units of measure for the z units when they are different from the x,y units of the input surface. The z-values of the input surface are multiplied by the z-factor when calculating the final output surface. If the x,y units and z units are in the same units of measure, the z-factor is 1. This is the default. If the x,y units and z units are in different units of measure, the z-factor must be set to the appropriate factor or the results will be incorrect. For example, if your z units are feet and your x,y units are meters, you would use a z-factor of 0.3048 to convert your z units from feet to meters (1 foot = 0.3048 meters). |
slope(ingrid) slope(ingrid, percentrise) slope(ingrid, .328) slope(ingrid, degree, 2)
ArcObjects syntax
ISurfaceOp::Slope (geoDataset As IGeoDataset, slopeType As esriGeoAnalysisSlopeEnum, [zFactor As Variant]) As IGeoDataset
| geoDataset | An input Raster, RasterDataset, RasterBand, or RasterDescriptor. |
| slopeType |
| zFactor | The number of ground x,y units in one surface z unit.
' Create the RasterSurfaceOp object
Dim pSurfaceOp As ISurfaceOp
Set pSurfaceOp = New RasterSurfaceOp
' Declare the input raster object
Dim pInputDataset As IGeoDataset
' Calls function to open a raster dataset from disk
Set pInputDataset = OpenRasterDataset ("D:\SpatialData", "inputdataset")
' Declare the output raster object
Dim pOutputRaster As IGeoDataset
' Calls the method
Set pOutputRaster = pSurfaceOp.Slope (pInputDataset, esriGeoAnalysisSlopeDegrees)
