Licensing for geoprocessing tools |
Release 9.3
Last modified April 24, 2009 |
![]() ![]() ![]() Print all topics in : "Geoprocessing tool reference" |
This topic was updated for 9.3.1.
The core toolboxes contain a mixture of tools available with specific license levels. These are shown
in the tables below. An X means the tool is available for that license level.
NOTE: The Coverage Tools toolbox is only available with an ArcInfo license. All tools provided with extensions are available at any license level.
All 3D Analyst tools are available at all license levels (ArcView, ArcEditor, and ArcInfo) if you have the ArcGIS 3D Analyst extension.
Toolset/Tool | ArcView | ArcEditor | ArcInfo |
Extract toolset |
Clip | x | x | x |
Select | x | x | x |
Split |
x |
Table Select | x | x | x |
Overlay toolset |
Erase |
x |
Identity |
x |
Intersect | x | x | x |
Spatial Join | x | x | x |
Symmetrical Difference |
x |
Union | x | x | x |
Update |
x |
Proximity toolset |
Buffer | x | x | x |
Create Thiessen Polygons |
x |
Generate Near Table |
x |
Multiple Ring Buffer | x | x | x |
Near |
x |
Point Distance |
x |
Statistics toolset |
Frequency |
x |
Summary Statistics | x | x | x |
Graphic Quality toolset |
Detect Graphic Conflict |
x |
Masking Tools toolset |
Cul-de-Sac Masks |
x |
Feature Outline Masks |
x |
Intersecting Layers Masks |
x |
Representation Management toolset |
Add Representation |
x |
Calculate Representation Rule |
x |
Drop Representation |
x |
Remove Override |
x |
Select Feature by Override |
x |
Set Layer Representation |
x |
Update Override |
x |
Symbolization Refinement toolset |
Align Marker to Stroke or Fill |
x |
Calculate Geodesic Angle |
x |
Calculate Line Caps |
x |
Calculate Polygon Main Angle |
x |
Create Overpass |
x |
Create Underpass |
x |
Disperse Markers |
x |
Set Representation Control Point At Intersect |
x |
Set Representation Contol Point By Angle |
x |
From Raster toolset |
Raster to ASCII | x | x | x |
Raster to Float | x | x | x |
Raster to Point | x | x | x |
Raster to Polygon | x | x | x |
Raster to Polyline | x | x | x |
From WFS |
WFS to Feature Class | x | x | x |
Metadata toolset |
ESRI Metadata Translator | x | x | x |
Metadata Importer | x | x | x |
Metadata Publisher | x | x | x |
USGS MP Metadata Translator | x | x | x |
XSLT Transformation | x | x | x |
To CAD toolset |
Add CAD Fields | x | x | x |
Create CAD XData | x | x | x |
Export to CAD | x | x | x |
Set CAD Alias | x | x | x |
To Coverage toolset |
Feature Class to Coverage |
x |
To dBASE toolset |
Table to dBASE (multiple) | x | x | x |
To Geodatabase toolset |
Feature Class to Feature Class | x | x | x |
Feature Class to Geodatabase (multiple) | x | x | x |
Import CAD Annotation | x | x | x |
Import Coverage Annotation | x | x | x |
Import from CAD | x | x | x |
Raster to Geodatabase (multiple) | x | x | x |
Table to Geodatabase (multiple) | x | x | x |
Table to Table | x | x | x |
To KML |
Layer to KML |
Map to KML |
To Raster toolset |
ASCII to Raster | x | x | x |
DEM to Raster | x | x | x |
Feature to Raster | x | x | x |
Float to Raster | x | x | x |
Point to Raster
NOTE: This tool is available with an ArcView or ArcEditor license if the Spatial Analyst extension or the 3D Analyst extension is installed. |
x |
Polygon to Raster
x |
Polyline to Raster
x |
Raster to Other Format (multiple) | x | x | x |
To Shapefile toolset |
Feature Class to Shapefile (multiple) | x | x | x |
All Coverage tools require an ArcInfo license. No Coverage tools are available with an ArcView or ArcEditor license.
All Data Interoperability tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Data Interoperability extension.
Create Address Locator | x | x | x |
Geocode Addresses | x | x | x |
Rebuild Address Locator | x | x | x |
Rematch Addresses | x | x | x |
Standardize Addresses | x | x | x |
All Geostatistical Analyst tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Geostatistical Analyst extension.
Calibrate Routes | x | x | x |
Create Routes | x | x | x |
Dissolve Route Events | x | x | x |
Locate Features Along Routes | x | x | x |
Make Route Event Layer | x | x | x |
Overlay Route Events | x | x | x |
Transform Route Events | x | x | x |
All Military Analyst tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Military Analyst extension.
Create Mobile Basemap | x | x | x |
Generate Mobile Service Cache | x | x | x |
All Military Overlay Editor (MOLE) tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Military Overlay Editor (MOLE) extension.
Feature to NetCDF | x | x | x |
Make NetCDF Feature Layer | x | x | x |
Make NetCDF Raster Layer | x | x | x |
Make NetCDF Table View | x | x | x |
Raster to NetCDF | x | x | x |
Select by Dimension | x | x | x |
Table to NetCDF | x | x | x |
All Network Analyst tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Network Analyst extension.
All Schematics tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Schematics extension.
Create Map Server Cache | x | x | x |
Delete Globe Server Cache | x | x | x |
Delete Map Server Cache | x | x | x |
Generate Map Server Cache Tiling Scheme | x | x | x |
Manage Globe Server Cache Tiles | x | x | x |
Manage Map Server Cache Scales | x | x | x |
Manage Map Server Cache Tiles | x | x | x |
All Spatial Analyst tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Spatial Analyst extension.
All Tracking Analyst tools are available at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Tracking Analyst extension.
