You are here:
Image and raster data management
Understanding raster data
This topic was updated for 9.3.1.
In its simplest form, a raster consists of a matrix of cells (or pixels) organized into rows and columns (or a grid) where each cell contains a value representing information, such as temperature. Rasters are digital aerial photographs, imagery from satellites, digital pictures, or even scanned maps.
Data stored in a raster format represents real-world phenomena, such as
data (also known as discrete), representing features such as land-use or soils data
data, representing phenomena such as temperature, elevation, or spectral data such as satellite images and aerial photographs
- Pictures such as scanned maps or drawings and building photographs
Thematic and continuous rasters may be displayed as data layers along with other geographic data on your map but are often used as the source data for spatial analysis with the ArcGIS Spatial Analyst extension. Picture rasters are often used as attributes in tables—they can be displayed with your geographic data and are used to convey additional information about map features.
Learn more about thematic and continuous data.
While the structure of raster data is simple, it is exceptionally useful for a wide range of applications. Within a , the uses of raster data fall under four main categories:
- Rasters as basemaps
A common use of raster data in a GIS is as a background display for other feature layers. For example, orthophotographs displayed underneath other layers provide the map user with confidence that map layers are spatially aligned and represent real objects as well as additional information. Three main sources of raster basemaps are orthophotos from aerial photography, satellite imagery, and scanned maps.
Below is a raster used as a basemap for road data.
- Rasters as surface maps
Rasters are well suited for representing data that changes continuously across a landscape (surface). They provide an effective method of storing the continuity as a surface. They also provide a regularly spaced representation of surfaces. Elevation values measured from the earth's surface are the most common application of surface maps, but other values, such as rainfall, temperature, concentration, and population density, can also define surfaces that can be spatially analyzed.
The raster below displays elevation—using green to show lower elevation and red, pink, and white cells to show higher elevation.
- Rasters as thematic maps
Rasters representing thematic data can be derived from analyzing other data. A common analysis application is classifying a satellite image by land-cover categories. Basically, this activity groups the values of multispectral data into classes (such as vegetation type) and assigns a categorical value. Thematic maps can also result from geoprocessing operations that combine data from various sources such as vector, raster, and terrain data. For example, you can process data through a geoprocessing model to create a raster dataset that maps suitability for a specific activity.
Below is an example of a classified raster dataset showing land use.
- Rasters as attributes of a feature
Rasters used as attributes of a feature may be digital photographs, scanned documents, or scanned drawings related to a geographic object or location. A parcel layer may have scanned legal documents identifying the latest transaction for that parcel, or a layer representing cave openings may have pictures of the actual cave openings associated with the point features.
Below is a digital picture of a large, old tree that could be used as an attribute to a landscape layer that a city may maintain.
Why store data as a raster?
Sometimes you don't have the choice of storing your data as a raster; for example, imagery is only available as a raster. However, there are many other features (such as points) and measurements (such as rainfall) that could be stored as either a raster or a feature (vector) data type.
The advantages of storing your data as a raster are as follows:
- A simple data structure—A matrix of cells with values representing a coordinate and sometimes linked to an attribute table
- A powerful format for advanced spatial and statistical analysis
- The ability to represent continuous surfaces and perform surface analysis
- The ability to uniformly store points, lines, polygons, and surfaces
- The ability to perform fast overlays with complex datasets
There are other considerations for storing your data as a raster that may convince you to use a vector-based storage option. For example:
- There can be spatial inaccuracies due to the limits imposed by the raster dataset cell dimensions.
- Raster datasets are potentially very large datasets. Resolution increases as the size of the cell decreases; however, normally cost also increases in both disk space and processing speeds. For a given area, changing cells to one-half the current size requires as much as four times the storage space, depending on the type of data and storage techniques used.
Learn more about cell size.
- There is also a loss of precision that accompanies restructuring data to a regularly spaced raster-cell boundary.
Learn more about representing features in a raster dataset.
General characteristics of raster data
In raster datasets, each cell (which is also known as a pixel) has a value. The cell values represent the phenomenon portrayed by the raster dataset such as a category, magnitude, height, or spectral value. The category could be a land-use class such as grassland, forest, or road. A magnitude might represent gravity, noise pollution, or percent rainfall. Height (distance) could represent surface elevation above mean sea level, which can be used to derive slope, aspect, and watershed properties. Spectral values are used in satellite imagery and aerial photography to represent light reflectance and color.
Cell values can be either positive or negative, integer, or floating point. Integer values are best used to represent categorical (discrete) data, and floating-point values to represent continuous surfaces. For additional information on discrete and continuous data, see Discrete and continuous data. Cells can also have a NoData value to represent the absence of data. For information on NoData, see NoData in raster datasets.
Rasters are stored as an ordered list of cell values, for example, 80, 74, 62, 45, 45, 34, and so on.
The area (or surface) represented by each cell consists of the same width and height and is an equal portion of the entire surface represented by the raster. For example, a raster representing elevation (that is, digital elevation model) may cover an area of 100 square kilometers. If there were 100 cells in this raster, each cell would represent one square kilometer of equal width and height (that is, 1 km x 1 km).
The dimension of the cells can be as large or as small as needed to represent the surface conveyed by the raster dataset and the features within the surface such as a square kilometer, square foot, or even a square centimeter. The cell size determines how coarse or fine the patterns or features in the raster will appear. The smaller the cell size, the smoother or more detailed the raster will be. However, the greater the number of cells, the longer it will take to process, and it will increase the demand for storage space. If a cell size is too large, information may be lost or subtle patterns may be obscured. For example, if the cell size is larger than the width of a road, the road may not exist within the raster dataset. In the diagram below, you can see how this simple polygon feature will be represented by a raster dataset at various cell sizes.
The location of each cell is defined by the row or column where it is located within the raster matrix. Essentially, the matrix is represented by a , in which the rows of the matrix are parallel to the x-axis and the columns to the y-axis of the Cartesian plane. Row and column values begin with 0. In the example below, if the raster is in a - and has a cell size of 100, the cell location at 5,1 would be 300,500 East, 5,900,600 North.
Learn about transforming the raster dataset.
Often you need to specify the extent of a raster. The extent is defined by the top, bottom, left, and right coordinates of the rectangular area covered by a raster, as shown below.
