Clip (Data Management) |
Release 9.1
Last modified June 25, 2007 |
Print all topics in : "Tools" |
Creates a spatial subset of a raster dataset. The clipped area is specified by a rectangular envelope.
The rectangular envelope extents are specified using minimum and maximum x and y coordinates.
Illustration
Usage tips
The Clip tool allows you to extract a portion of a raster dataset based on a rectangular extent.
The minimum and maximum x and y extents allow you to define the clip extents for your output raster dataset.
The extent values must be in the same spatial coordinates and units as the raster dataset.
ArcObjects
The envelope defines the clip extent for your output raster dataset. The envelope values represent the lower left coordinate's x value and y value, then the upper right coordinate's x value and y value.
The output raster will have the same cellsize as the input raster.
Command line syntax
Introducing geoprocessing methods—Using dialog boxes and the command line
Clip_management <in_raster> <rectangle> <out_raster>
| Parameter | Explanation |
| <in_raster> |
Input raster dataset. |
| <rectangle> |
The rectangle defining the area to be clipped. Define in this order: X-Minimum, Y-Minimum, X-Maximum, Y-Maximum. |
| <out_raster> |
Output raster dataset. When not saving to a geodatabase, specify .tif for a TIFF file format, .img for an ERDAS IMAGINE file format, or no extension for a GRID file format. |
Clip_management D:\images\OverviewImage\Layer_1 '549790 5272863 549870 5273000' D:\images\ClippedOverview1
Scripting syntax
Introducing geoprocessing methods—Running a script
Clip_management (in_raster, rectangle, out_raster)
| in_raster (Required) |
| rectangle (Required) |
| out_raster (Required) |
from win32com.client import Dispatch
gp = Dispatch('esriGeoprocessing.GpDispatch.1')
gp.workspace = "c:/seattle_data"
gp.Clip_management("seattle1.tif","549790.051000 5272863.993000 549870.051000 5273000.993000","seattle_clip.img")
Map Algebra syntax
Not available.
ArcObjects syntax
ITransformationOp::Clip(GeoDataset As IGeoDataset, Rectangle As IEnvelope) As IGeoDataset
| GeoDataset | An input Raster, RasterDataset RasterBand or RasterDescriptor. |
| Rectangle | An IEnvelope identifying the lower-left and upper-right coordinates of the rectangle defining the area to be subset from the input GeoDataset. |
