Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Analysis toolbox > Overlay toolset > Tools
Symmetrical Difference (Analysis) (ArcInfo only)
Release 9.1
Last modified August 15, 2005
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Computes a geometric intersection of the input and update features. Features or portions of features in the input and update features which do not overlap will be written to the Output Feature Class.
Learn more about how Symmetrical Difference works
Illustration
Symmetrical Difference illustration
Usage tips
Command line syntax
Introducing geoprocessing methods—Using dialog boxes and the command line
SymDiff_analysis <in_features> <update_features> <out_feature_class> {NO_FID | ONLY_FID | ALL} {cluster_tolerance}
Parameter Explanation
<in_features>
The input feature class or layer. Geometry type must be polygon.
<update_features>
The update feature class or layer. Geometry type must be polygon.
<out_feature_class>
The feature class to which the results will be written.
Determines which attributes will be transferred to the Output Feature Class.
  • ALL—All the attributes from the Input Features and Update Features will be transferred to the output. This is the default.
  • NO_FID—All the attributes except the FID Input Features and Update Features will be transferred to the output.
  • ONLY_FID—Only the FID from the Input Features and Update Features will be transferred to the output.
{cluster_tolerance}
Cluster tolerance is the distance range in which all vertices and boundaries in a feature class are considered identical or coincident. To minimize error, the cluster tolerance chosen should be as small as possible, depending on the precision level of your data. By default, the minimum possible tolerance value is calculated in the units of the spatial reference of the input.
Command line example
workspace d:\test_data
symdiff forest\polygon cutzones.shp gdb.mdb\futurecut no_fid 0.25
Scripting syntax
Introducing geoprocessing methods—Running a script
SymDiff_analysis (in_features, update_features, out_feature_class, join_attributes, cluster_tolerance)
in_features (Required)
update_features (Required)
out_feature_class (Required)
join_attributes (Optional)
cluster_tolerance (Optional)
Script example
# Create the geoprocessor
import win32com.client
gp = win32com.client.Dispatch("esriGeoprocessing.GPDispatch.1")
# Use error trapping in case a problem occurs when running the SymDiff tool
try:
    gp.SymDiff("c:/test_data/covs/forest", "c:/test_data/shp/cutzones.shp", "c:/test_data/gdb.mdb/futurecut", "only_fid" "0.25")
except:
    print gp.GetMessage()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
