You are here:
Editing in ArcMap
Editing existing features
About extending lines
The Extend task is the opposite of the Trim task (see Trimming lines); it extends selected lines to a line you construct. Suppose your database has some roads that should end at the coastline but instead stop short. After you draw a sketch on top of the coastline, you can use the Extend task to extend the roads to the sketch you drew.
In addition to the basic editing functionality described above, a more complex set of editing tools is available from the Advanced Editing toolbar. One of these tools is the Extend tool
, which lets you click a line feature and extend it to another selected line feature.
How to extend lines
Extending using basic editing tools
- Click the Current Task dropdown arrow and click Extend/Trim Features.
- Click the Edit tool
- Click the line to be extended.
- Click the Tool Palette dropdown arrow and click the Sketch tool
- Construct a line to where you want the selected line or lines to be extended. The lines will be extended to where they intersect the sketch. The sketch line does not have to be perpendicular to the selected lines, but the selected lines must be able to intersect the sketch for them to be extended.
- Right-click anywhere on the map and click Finish Sketch.
The lines are extended to the line you constructed.
- You can also use the Distance–Distance tool, the Arc tool, or the Intersection tool to create a sketch. For more information, see About creating new features.
- You can double-click the last vertex of a sketch to finish it, or you can press F2.
- If the sketch line intersects the selected lines, the lines will be trimmed instead of extended.
Extending using advanced editing tools
- Select the line segment to which you want to extend a line.
- If you have not done so already, add the Advanced Editing toolbar to ArcMap.
- On the Advanced Editing toolbar, click the Extend tool
- Click the end of the feature you want to extend.
The line you click is extended to the selected line.
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
