ListFields method |
Release 9.1
Last modified August 19, 2005 |
![]() ![]() ![]() Print all topics in : "Properties and Methods" |
List all the fields in the specified table, feature class, or shapefile. Specifying search conditions (wildcard) and a field type will limit the results. This method and ListIndexes are the only two List methods that don’t require the user to preset the workspace.
Part | Description |
object | The instantiated geoprocessing object |
pInputValue | The name, and/or path, of the table whose fields are to be listed |
wild card | Optional. Combination of * and characters that will help limit the results. The asterisk (*) is the same as saying ALL. If no wildcard is specified then all fields will be returned. |
FieldType | Optional. Keyword FieldType that will limit the returned fields. Valid FieldTypes for this method are:
import win32com.client, sys, os gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1") # Check the number of arguments. if len(sys.argv) < 2: print "Script requires two arguments, feature class and field name" else: try: # Get the input feature class and make sure it contains polygons. input = sys.argv[1] dsc = gp.Describe(input) if dsc.ShapeType != "polygon": raise "ShapeError" # Get the new field name and validate it. fieldname = sys.argv[2] fieldname = gp.ValidateFieldName(fieldname, os.path.dirname(input)) # Make sure shape_length and shape_area fields exist. if gp.ListFields(input,"Shape_area").Next() and gp.ListFields(input,"Shape_length").Next(): # Add the new field and calculate the value. gp.AddField(input, fieldname, "double") gp.CalculateField(input,fieldname, "[Shape_area] / [Shape_length]") else: raise "FieldError" except "ShapeError": print "Input does not contain polygons" except "FieldError": print "Input does not shape area and length fields" except: print gp.GetMessages(2)
