QualifyTableName method |
Release 9.1
Last modified August 19, 2005 |
![]() ![]() ![]() Print all topics in : "Properties and Methods" |
Prefixes a name string with the database.username, if required. This method is used in scripting only.
Part | Description |
object | The instantiated geoprocessor object |
InputTableName | Specifies which table will be prefixed |
Workspace | Specifies the workspace in which the table can be found |
from win32com.client import Dispatch gp = Dispatch("esriGeoprocessing.GpDispatch.1") # Create the list of input featureclasses. gp.Workspace = "Database Connections\\Calgary.sde\\transportation" fcs = gp.Listfeatureclasses() fc = fcs.Next() while fc: outfc = gp.ValidateTableName(fc, "Database Connections\\Calgary.sde\\clip") # Qualify the clip fc name as it is owned by Grace. clipfc = gp.QualifyTableName("Grace", "study_area", "Connections\\Calgary.sde") try: gp.Clip(fc, clipfc, outfc) except: print gp.GetMessages(2) print "Successfully clipped " + fc
