Changing the default RGB band combination |
Release 9.1
Last modified December 7, 2006 |
![]() ![]() ![]() Print all topics in : "Working with rasters in ArcMap" |
When you add a single-band raster dataset, the value of each cell is drawn as a color or a shade of gray, depending on the data. When you add a multiband raster dataset, three of its bands are combined to form a composite image, where each band supplies either the red, green, or blue display value. From the Raster tab in the Options dialog box, you can choose which band will provide which value. You can specify a different set of defaults, mapping bands to RGB display values for datasets with three bands and those with four or more bands.
