Using the ArcGIS Spatial Analyst toolbar to calculate Viewshed |
Release 9.2
Last modified May 2, 2007 |
By calculating viewshed, the cells in an input raster that can be seen from one or more observation points or lines can be identified.
This is useful for applications in which the visibility of an object is important—such as finding well-exposed places for communications towers.
You can control the visibility in the Viewshed tool by setting some optional parameters. To use the optional parameters OFFSETA, OFFSETB, RADIUS1, and so on, add these fields to the feature attribute table. Each feature can have different values for these parameters. Once these fields are added, they will automatically be used when you open the Viewshed tool.
Learn more about optional parameters
Learn more about calculating viewshed
Learn how to calculate viewshed using the Viewshed tool
Learn about other Spatial Analyst toolbar functions
| Tips |
| Tip |
SPOT, OFFSETA, OFFSETB, AZIMUTH1, AZIMUTH2, VERT1, and VERT2 store visibility parameters in the Feature Attribute table. |
