unzip python script |
Release 9.2
Last modified November 9, 2007 |
# File name: Unzip.py
# Description:
# Unzips the contents of a zip file into a new folder, file geodatabase or ArcInfo
# workspace. If the zip file contains a file geodatabase, the output workspace name should
# be given a .gdb extension.
# Arguments:
# 0 - Input zip file
# 1 - Output location that will contain the new workspace
# 2 - The name of the new workspace
# Created by: ESRI
# Import modules and create the geoprocessor
import sys, zipfile, arcgisscripting, os, traceback
gp = arcgisscripting.create()
# Function for unzipping the contents of the zip file
def unzip(path, zip):
isdir = os.path.isdir
join = os.path.join
norm = os.path.normpath
split = os.path.split
# If the output location does not yet exist, create it
if not isdir(path):
os.makedirs(path)
for each in zip.namelist():
gp.AddMessage("Extracting " + os.path.basename(each) + " ...")
# Check to see if the item was written to the zip file with an
# archive name that includes a parent directory. If it does, create
# the parent folder in the output workspace and then write the file,
# otherwise, just write the file to the workspace.
if not each.endswith('/'):
root, name = split(each)
directory = norm(join(path, root))
if not isdir(directory):
os.makedirs(directory)
file(join(directory, name), 'wb').write(zip.read(each))
if __name__ == '__main__':
try:
# Get the tool parameter values
infile = sys.argv[1]
outloc = sys.argv[2]
outname = sys.argv[3]
outfol = outloc + "\\" + outname
# Create the zipfile handle for reading and unzip it
zip = zipfile.ZipFile(infile, 'r')
unzip(outfol, zip)
zip.close()
gp.setparameterastext(3, outfol)
except:
# Return any python specific errors and any error returned by the geoprocessor
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n " + str(sys.exc_type)+ ": " + str(sys.exc_value) + "\n"
gp.AddError(pymsg)
msgs = "GP ERRORS:\n" + gp.GetMessages(2) + "\n"
gp.AddError(msgs)
