Buffer (Analysis) |
Release 9.2
Last modified January 13, 2009 |
Print all topics in : "Tools" |
Creates buffer polygons to a specified distance around the Input Features. An optional dissolve can be performed to remove overlapping buffers.
Learn more about how Buffer works
Learn more about Buffering complex features
Illustration
Usage tips
Features will not be buffered if their buffer distance is zero. If you don't want to have a feature buffered in the Output Feature Class, assign it a buffer distance value of zero in the distance field.
Negative distances can be used when buffering polygon features, to create buffers on the inside of the polygon features. Using a negative value will shrink the output polygon feature by the distance specified.
The LEFT and RIGHT options generate buffers at the topological left or right of a line. Caution must be exercised in interpreting the left or right side of a polyline. With connecting polylines, the left side of one polyline may be on the right side of another connecting polyline.
Using the Dissolve Type parameter ALL option will dissolve all buffer polygons into a single multipart polygon feature. Buffers of related features can be dissolved together using the Dissolve Type parameter LIST option and a set of fields for Dissolve Fields. Buffer features with the same values in their Dissolve Fields will be dissolved together.
Using ALL or LIST for the Dissolve parameter may result in multipart features being created.
The Side Type and End Type parameters apply only to line features.
Side Type's LEFT and RIGHT options and End Type's FLAT option are only available with an ArcInfo licence.
Buffer will expand the XYDomain of the Output Feature Class to accommodate potential buffer features beyond the Input Feature's XYDomain.
Using the Dissolve Type parameter's NONE option will add a 'BUFF_DIST' field to the Output Feature Class that will show the buffer distance used for each feature.
The buffered edges of a LEFT or RIGHT side buffer are different from those created by a FULL buffer due to differences in the algorithms used to create the buffers. When using the LEFT or RIGHT option, a vertex is placed at every degree along the point of rotation, the value is smaller using the FULL option, which creates a smoother line. The difference between the two is within the precision of the Input Features.
Buffer can create very large multipart polygon features when using the Dissolve option. This is especially true when using a small number of Dissolve Field(s) or when dissolving all polygons into a single polygon. Very large polygon features may cause display problems and/or have poor performance when drawn on a map or when edited. To avoid these potential problems, use Multipart To Singlepart on Buffer's output to split larger multipart features into many smaller features.
When using the results of Buffer as input to an overlay operation such as Union or Intersect, it is recommended that Buffer output be dissolved in order to reduce the number of features and overlap. This can be done when only a subset of the Input Feature's attributes are necessary for the analysis being performed. This will reduce the number of spatial relationships between the input features being processed, thereby reducing the amount of memory the tool requires and the amount of time required for processing.
The Dissolve Fields parameter Add Field button is used only in ModelBuilder. In ModelBuilder, where the preceding tool has not been run, or it's derived data does not exist, the Dissolve Fields parameter may not be populated with field names. The Add Field button allows you to add expected fields so you can complete the Buffer dialog and continue to build your model.
The following environments affect this tool: configKeyword, extent, MDomain, outputCoordinateSystem, outputMFlag, outputZFlag, outputZValue, scratchWorkspace, spatialGrid1, spatialGrid2, spatialGrid3, workspace, XYDomain, and ZDomain.
Command line syntax
An overview of the Command Line window
Buffer_analysis <in_features> <out_feature_class> <buffer_distance_or_field> {FULL | LEFT | RIGHT} {ROUND | FLAT} {NONE | ALL | LIST} {dissolve_field;dissolve_field...}
| Parameter | Explanation | Data Type |
| <in_features> |
The features to be buffered. |
Feature Layer |
| <out_feature_class> |
The feature class that will contain the buffer features. |
Feature Class |
| <buffer_distance_or_field> |
The distance used to create buffer zones around Input Features. Either a value or a numeric field can be used to provide buffer distances. For polygon features, if a negative buffer distance is used, buffers will be generated on the insides of polygons. If the distance units are not specified, or entered as 'Unknown', the units of the Input Features are used (or if the Output Coordinate System environment has been set, its units will be used). |
Linear unit | Field |
| {FULL | LEFT | RIGHT} |
The side(s) of a line that will be buffered.
The LEFT and RIGHT options are not available with an ArcView or ArcEditor license. |
String |
| {ROUND | FLAT} |
For lines, the shape of the buffer at the line end points.
String |
| {NONE | ALL | LIST} |
Specifies whether a dissolve will be performed to remove buffer feature overlap.
String |
| {dissolve_field;dissolve_field...} |
List of field(s) for the dissolve. Buffer polygons that share the same set of values in their Dissolve Field(s) will be dissolved together. The Add Field button, which is used only in ModelBuilder, allows you to add expected field(s) so you can complete the dialog and continue to build your model. |
Field |
Buffer_analysis c:\basedata\road.shp c:\basedata\buffered_roads.shp '200 Feet' FULL FLAT
Scripting syntax
About getting started with writing geoprocessing scripts
Buffer_analysis (in_features, out_feature_class, buffer_distance_or_field, line_side, line_end_type, dissolve_option, dissolve_field)
| in_features (Required) |
Feature Layer |
| out_feature_class (Required) |
Feature Class |
| buffer_distance_or_field (Required) |
| line_side (Optional) |
String |
| line_end_type (Optional) |
String |
| dissolve_option (Optional) |
String |
| dissolve_field (Optional) |
Field |
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "c:/basedata"
gp.toolbox = "analysis"
# Buffer roads.shp based on each road feature's value in the Distance field,
# and dissolve buffers into groups according to values from Road_Type field.
gp.buffer("roads.shp", "buffered_roads.shp", "Distance", "FULL", "ROUND", "LIST", "Road_Type")
