Frequency (Analysis) (ArcInfo only) |
Release 9.2
Last modified January 13, 2009 |
Print all topics in : "Tools" |
Creates a list of the unique code occurrences and their frequency for a specified set of items in an table.
Usage tips
The Output Table will contain the field Frequency and the specified frequency field(s) and summary field(s).
The output table will contain the frequency calculation for each attribute value combination of the specified frequency field(s).
If a summary field is specified, the unique attribute values of the frequency calculation are summarized by the numeric attribute values of each summary field.
Current map layers may be used to define the Output Table. When using layers, only the currently selected features are used in the Frequency operation.
The following environment setting affects this tool: Configuration Keyword.
Command line syntax
An overview of the Command Line window
Frequency_analysis <in_table> <out_table> <frequency_fields; frequency_fields...> {summary_fields; summary_fields...}
| Parameter | Explanation | Data Type |
| <in_table> |
The table containing the field(s) that will be used to calculate frequency statistics. It can be an INFO or OLE DB table, a dBASE or a VPF table, or a feature class. |
Table View | Raster Layer |
| <out_table> |
The table that will store the calculated frequency statistics. |
Table |
| <frequency_fields; frequency_fields...> |
The attribute field or fields that will be used to calculate frequency statistics. |
Field |
| {summary_fields; summary_fields...} |
The attribute field or fields that will be used to summarize the frequency results. |
Field |
' Purpose: Determine the total amount of sales for each ' different customer type within each ZIP Code. ' ' Customer data includes customer name and address, ' the type of customer(restaurant, store, service station) ' and the amount of sales for each customer. ' ' The following sample output shows the summarizing of values ' for each unique attribute value: ' FREQUENCY TYPE ZIP SALES ' 3 Cafe 30308 144438.80 ' 3 Cafe 30309 192024.17 ' 2 Theater 30308 110825.41 ' 1 Theater 30312 30117.69 ' 1 Theater 30318 55799.80 ' workspace E:\arcgis\ArcTutor\Geocoding\Atlanta\Atlanta.mdb Frequency customers customers_freq type;zip SALES
Scripting syntax
About getting started with writing geoprocessing scripts
Frequency_analysis (in_table, out_table, frequency_fields, summary_fields)
| in_table (Required) |
| out_table (Required) |
Table |
| frequency_fields (Required) |
Field |
| summary_fields (Optional) |
Field |
# Purpose: Break all multipart features into singlepart features,
# and generate a report of which features were separated.
# Create the geoprocessor
import arcgisscripting
gp = arcgisscripting.create()
# Create variables for the input and output feature classes
inFeatureClass = "c:/gdb.mdb/vegetation"
outFeatureClass = "c:/gdb.mdb/vegetation_singlepart"
# Use error trapping in case a problem occurs when running the tool
try:
# Add a field to the input (if not already present), this will be used as a unique identifier
if not gp.ListFields(inFeatureClass,"tmpUID").Next():
gp.AddField(inFeatureClass, "tmpUID","double")
# Determine what the name of the Object ID is
fields = gp.listfields(inFeatureClass, "","oid")
OidFieldName = fields.next().name
# Calculate the tmpUID to the OID since this is a Personal GDB, wrap the Field inside []
exp = "[" + OidFieldName + "]"
gp.CalculateField(inFeatureClass, "tmpUID", exp)
# Run the tool to create a new fc with only singlepart features
gp.MultipartToSinglepart(inFeatureClass,outFeatureClass)
# Check if there is a different number of features in the output than there was in the input
if (gp.GetCount(inFeatureClass) == (gp.GetCount(outFeatureClass))):
print "The number of features in the input is the same as in the output, so no multipart features were found"
else:
# If there is a difference, print out the FID of the input features which were multipart
gp.Frequency(outFeatureClass, outFeatureClass + "_freq", "tmpUID")
# Use a search cursor to go through the table, and print the tmpUID
print "Below is a list of the FIDs of all the multipart features from " + inFeatureClass
rows = gp.SearchCursor(outFeatureClass + "_freq", "[FREQUENCY] > 1")
row = rows.next()
while row:
print int(row.tmpUID)
row = rows.next()
except:
# If an error occurred, print out the error message
print "Error occurred"
print gp.GetMessages()
