Table to dBASE (multiple) (Conversion) |
Release 9.2
Last modified April 2, 2008 |
Print all topics in : "Tools" |
Converts one or more tables to dBASE tables. The inputs can be dBASE, INFO, geodatabase, or OLE DB tables.
Usage tips
The name of the output tables will be based on the name of the input table. For example, if the input is c:\gdb.mdb\Gondor, the output dBASE table will be named gondor.dbf. To explicitly control the output name and for some additional conversion options, use the Table To Table tool.
The Copy Rows and Table To Table can also be used to convert a table to a dBASE file.
If the name of the output table already exists in the output folder, a number will be appended to the end to make it unique (for example, OutputTab_1.dbf).
Command line syntax
An overview of the Command Line window
TableToDBASE_conversion <Input_Table;Input_Table...> <Output_Folder>
| Parameter | Explanation | Data Type |
| <Input_Table;Input_Table...> |
The list of tables to be converted to dBASE. These can be INFO, geodatabase, OLE DB, or dBASE tables. It can also be a table view (a table in the ArcMap table of contents [TOC] or the result of running MakeTableView tool); if this is the case, only selected records will be in the output. |
Table View |
| <Output_Folder> |
The output or destination folder. |
Folder |
TableTodBASE "c:\data\mydbase.dbf;c:\data\myinfo.dat;c:\mygdb.mdb\tab1" c:\myFolder
Scripting syntax
About getting started with writing geoprocessing scripts
TableToDBASE_conversion (Input_Table, Output_Folder)
| Input_Table (Required) |
Table View |
| Output_Folder (Required) |
Folder |
# ConvertTodBASEExample.py
# Description: Simple example showing a use of the TableTodBASE
# Requirements: Python and the Python win32all extension
# Author: ESRI
# Data 1/6/2004
# Create the Geoprocessor
import arcgisscripting
gp = arcgisscripting.create()
# Put in error trapping in case an error occurs when running tool
try:
# Set the workspace, then export list of SDE table
gp.Workspace = "Database Connections/Connection to Doosie.sde"
gp.FeatureClassToShapefile("ED.Owners ; ED.StoresInfo ; ED.Sales","c:/geodata/tables")
except:
# If an error occurred print the message to the screen
print gp.GetMessages()
