Add Global IDs (Data Management) (ArcInfo and ArcEditor only) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Adds global IDs to a list of geodatabase classes, tables and/or feature datasets
Learn more about creating replicas
Learn more about preparing data for replication
Usage tips
If the geodatabase is a personal or file geodatabase then the datasets must be schema only
The following environment settings affect this tool: workspace, scratch workspace, and Configuration keyword.
Command line syntax
An overview of the Command Line window
AddGlobalIDs_management <in_dataset_list>
| Parameter | Explanation | Data Type |
| <in_dataset_list> |
A list of geodatabase classes, tables and/or feature datasets that global Ids will be added to. |
Layer | Table View | GeoDataset |
AddGlobalIDs roads
Scripting syntax
About getting started with writing geoprocessing scripts
AddGlobalIDs_management (in_dataset_list)
| in_dataset_list (Required) |
# Create the Geoprocessor object
import arcgisscripting, sys, scripting, os
gp = arcgisscripting.create()
# Set the necessary product code
gp.SetProduct("ArcInfo")
# Load required toolboxes...
gp.AddToolbox("Data Management Tools.tbx")
# Process: Add Global IDs...
gp.AddGlobalIDs("Roads")
