An overview of the Domains toolset |
Release 9.2
Last modified October 31, 2007 |
Print all topics in : "Domains toolset" |
Domains offer a way to define a range of values that can be used for multiple attribute fields. Using domains helps ensure data integrity by limiting the choice of values for a particular field. Validation for coded value domains is accomplished by restricting the user to choose field values from a dropdown list. Range domains are automatically validated during editing.
The following table lists the tools available in the Domains toolset and provides a brief description of each.
NOTE: Tool availability is determined by the ArcGIS license. Licensing requirements for each tool are listed below.
| Tool | Description |
| Add Coded Value To Domain | Adds a value to a domain's coded value list. Available with any ArcGIS license. |
| Assign Domain To Field | Sets the domain for a particular field and optionally for a subtype. Available with any ArcGIS license. |
| Create Domain | Creates an attribute domain in the specified workspace. Available with any ArcGIS license. |
| Delete Coded Value From Domain | Removes a value from a coded value domain. Available with any ArcGIS license. |
| Delete Domain | Deletes a domain from a workspace. Available with any ArcGIS license. |
| Domain To Table | Creates a table from an attribute domain. Available with any ArcGIS license. |
| Remove Domain From Field | Removes an attribute domain association from a feature class field. Available with any ArcGIS license. |
| Set Value For Range Domain | Sets the minimum and maximum values for an existing range domain. Available with any ArcGIS license. |
| Table To Domain | Updates a coded value domain with values from a table. Available with any ArcGIS license. |
