Adjust 3D Z (Data Management) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Allows the modification of all Z values in a Z enabled Feature Class.
Usage tips
Bathymetry data often has positive Z-values. You may wish to reverse the signs of all the data in the Feature Class to make it negative.
Z-enabled data could be referenced to a vertical datum that is not appropriate for your geoprocessing needs. This tool could apply a bulk-shift of all the Z-values in the Feature Class to adjust the data either up or down vertically.
If your Z-values represent units that aren't consistent with your other data, or you'd like to convert them to another unit, we have included several common unit conversions.
The following environment settings affect this tool: Z Tolerance, Output Z domain, Output has Z values, Default Z value.
Command line syntax
An overview of the Command Line window
Adjust3DZ_management <in_features> {NO_REVERSE | REVERSE} {adjust_value} {MILLIMETERS | CENTIMETERS | METERS | INCHES | FEET | YARDS | FATHOMS} {MILLIMETERS | CENTIMETERS | METERS | INCHES | FEET | YARDS | FATHOMS}
| Parameter | Explanation | Data Type |
| <in_features> |
The input feature class containing Z-values in the SHAPE field. |
Feature Layer |
| {NO_REVERSE | REVERSE} |
Flips the sign of all the Z values in the feature class. |
String keyword |
| {adjust_value} |
This parameters allows you to specify a value for a bulk shift. To decrease the z-values for the entire feature class, enter a negative number. To increase, enter a positive value. |
Double |
| {MILLIMETERS | CENTIMETERS | METERS | INCHES | FEET | YARDS | FATHOMS} |
This parameter specifies the units that the z values will be converted from. Available conversion factors are:
centimeters meters inches feet yards fathoms This parameter is used in conjunction with Convert To Units. |
String keyword |
This parameter specifies the units that the z values will be converted to. Available conversion factors are:
centimeters meters inches feet yards fathoms This parameter is used in conjunction with Convert From Units. |
String keyword |
Adjust3DZ C:\Tutorial\sample_data.gdb\tutorial\depths REVERSE # #Bulk Shift Adjustment Example:
Adjust3DZ C:\Tutorial\sample_data.gdb\tutorial\coastline # 10.5 # #Unit Conversion Example:
Adjust3DZ C:\Tutorial\sample_data.gdb\tutorial\breaklines # # FEET METERS
Scripting syntax
About getting started with writing geoprocessing scripts
Adjust3DZ_management (in_features, reverse_sign, adjust_value, from_units, to_units)
| in_features (Required) |
Feature Layer |
| reverse_sign (Optional) |
String keyword |
| adjust_value (Optional) |
Double |
| from_units (Optional) |
String keyword |
| to_units (Optional) |
String keyword |
# Name: adjust3dz.py # Description: This python file tests the functionality of Adjust3DZ, specifically for: # 1. REVERSE signs of Z-values in Z enabled multipoint feature class # 2. BULK SHIFT of Z-values in Z enabled polyline feature class # 3. COORDINATE CONVERSION of units in Z-enabled point feature class # Requirements: Python and the Python win32all extension # Author: ESRI # Date 1/1/2009 # Create the Geoprocessor import arcgisscripting, time gp = arcgisscripting.create() gp.overwriteoutput = 1 # 1. REVERSE signs of Z-values in Z enabled multipoint feature class inFClass = "test_adjust.gdb\\topography\\multipoint_test" signage = "REVERSE" adjust = " " from_units = " " to_units = " " print "Executing REVERSE Adjust3DZ test." adjust3dz_management (inFClass, signage, adjust, from_units, to_units) # 2. BULK SHIFT of Z-values in Z enabled polyline feature class inFClass = "test_adjust.gdb\\topography\\breaklines" signage = " " adjust = "10.5" from_units = " " to_units = " " print "Executing BULK_SHIFT Adjust3DZ test." adjust3dz_management (inFClass, signage, adjust, from_units, to_units) # 3. COORDINATE CONVERSION of units in Z-enabled point feature class inFClass = "test_adjust.gdb\\topography\\points_test" signage = " " adjust = " " from_units = "FEET" to_units = "METERS" print "Executing UNIT_CONVERSION Adjust3DZ test." adjust3dz_management (inFClass, signage, adjust, from_units, to_units) print "Finished Adjust3DZ tests."
