Calibrate Routes (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
Print all topics in : "Tools" |
Recalculates route measures using points.
Usage tips
The outputMFlag environment setting will be ignored. The Output Route Feature Class will have M (measure) values.
If the Output Route Feature Class will be written to a geodatabase, an appropriate MTolerance, MResolution and MDomain should be set.
The Output Route Feature Class will include all the fields from the Input Features.
Use Make Feature Layer or Make Query Table to effectively reduce the routes that will be calibrated.
Either whole or partial routes can be calibrated. You can choose to interpolate between the input points, extrapolate before the input points, extrapolate after the input points, or use any combination of these three methods.
A search radius of infinity cannot be specified.
An attribute index on the route identifier field speeds up the dynamic segmentation process. If you will be using the Output Route Feature class for dynamic segmentation, it is recommended that you choose to have an attribute index created.
If any features are rejected by the Calibrate Routes process, a text file is created in the temporary file path to store information about those features. For example, C:\Documents and Settings\patrickb\Local Settings\Temp\Calibrate_Output0.txt (where 'Calibrate_Output' is the name of the Output Route Feature Class).
The following environments affect this tool: configKeyword, extent, MTolerance, MResolution, MDomain, outputCoordinateSystem, outputZFlag, scratchWorkspace, spatialGrid1, spatialGrid2, spatialGrid3, workspace, XYDomain, and ZDomain.
Command line syntax
An overview of the Command Line window
CalibrateRoutes_lr <in_route_features> <route_id_field> <in_point_features> <point_id_field> <measure_field> <out_feature_class> {DISTANCE | MEASURES} {search_radius} {BETWEEN | NO_BETWEEN} {BEFORE | NO_BEFORE} {AFTER | NO_AFTER} {IGNORE | NO_IGNORE} {KEEP | NO_KEEP} {INDEX | NO_INDEX}
| Parameter | Explanation | Data Type |
| <in_route_features> |
The route features to be calibrated. |
Feature Layer |
| <route_id_field> |
The field containing values that uniquely identify each route. This field can be numeric or character. |
Field |
| <in_point_features> |
The point features used to calibrate the routes. |
Feature Layer |
| <point_id_field> |
The field that identifies the route on which each calibration point is. The values in this field match those in the route identifier field. This field can be numeric or character. |
Field |
| <measure_field> |
The field containing the measure value for each calibration point. This field must be numeric. |
Field |
| <out_feature_class> |
The feature class to be created. It can be a shapefile or a geodatabase feature class. |
Feature Class |
| {DISTANCE | MEASURES} |
Specifies how route measures will be recalculated.
String |
| {search_radius} |
Limits how far a calibration point can be from a route by specifying the distance and its unit of measure. If the units of measure are Unknown, the same units as the coordinate system of the route feature class will be used. |
Linear unit |
| {BETWEEN | NO_BETWEEN} |
Specifies whether measure values will be interpolated between the calibration points.
Boolean |
| {BEFORE | NO_BEFORE} |
Specifies whether measure values will be extrapolated before the calibration points.
Boolean |
| {AFTER | NO_AFTER} |
Specifies whether measure values will be extrapolated after the calibration points.
Boolean |
| {IGNORE | NO_IGNORE} |
Specifies whether spatial gaps will be ignored when recalculating the measures on disjointed routes.
Boolean |
| {KEEP | NO_KEEP} |
Specifies whether route features that do not have any calibration points will be excluded from the output feature class.
Boolean |
| {INDEX | NO_INDEX} |
Specifies whether an attribute index will be created for the route identifier field that is written to the Output Route Feature Class.
Boolean |
Workspace "C:\Data" CalibrateRoutes_lr hwy.shp route1 cal_pts.shp route1 measure hwy_new DISTANCE "5.0 feet" BETWEEN BEFORE AFTER # NO_KEEP Workspace "C:\Data\Pitt.mdb" CalibrateRoutes_lr roads\hwy route1 roads\cal_pts route1 measure roads\hwy_new DISTANCE "2.5 meters" BETWEEN NO_BEFORE NO_AFTER Workspace "C:\Data\Pitt.gdb" CalibrateRoutes_lr roads\hwy route1 roads\cal_pts route1 measure roads\hwy_new DISTANCE "2.5 meters" BETWEEN BEFORE AFTER Workspace "Database Connections\Connection to Jerry.sde" CalibrateRoutes_lr gdb.hwy route1 gdb.cal_pts route1 measure hwy_new DISTANCE "5.0 feet" # # # # NO_KEEP
Scripting syntax
About getting started with writing geoprocessing scripts
CalibrateRoutes_lr (in_route_features, route_id_field, in_point_features, point_id_field, measure_field, out_feature_class, calibrate_method, search_radius, interpolate_between, extrapolate_before, extrapolate_after, ignore_gaps, keep_all_routes, build_index)
| in_route_features (Required) |
Feature Layer |
| route_id_field (Required) |
Field |
| in_point_features (Required) |
Feature Layer |
| point_id_field (Required) |
Field |
| measure_field (Required) |
Field |
| out_feature_class (Required) |
Feature Class |
| calibrate_method (Optional) |
String |
| search_radius (Optional) |
Linear unit |
| interpolate_between (Optional) |
Boolean |
| extrapolate_before (Optional) |
Boolean |
| extrapolate_after (Optional) |
Boolean |
| ignore_gaps (Optional) |
Boolean |
| keep_all_routes (Optional) |
Boolean |
| build_index (Optional) |
Boolean |
# Example 1:
# Calibrate shapefile routes using shapefile points.
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
gp.Workspace = "C:/Data"
rts = "hwy.shp"
rid = "ROUTE1" # used for both route-id and point-id
pts = "cal_pts.shp"
mfield = "MEASURE"
radius = "5.0 Feet"
out_fc = "hwy_new" # new shapefile that will be created
gp.CalibrateRoutes_lr (rts, rid, pts, rid, mfield, out_fc, "DISTANCE", radius, "BETWEEN", "BEFORE", "AFTER", "#", "NO_KEEP")
except:
print gp.GetMessages(2)
# Example 2:
# Calibrate personal geodatabase routes with file geodatabase points.
try:
gp.Workspace = "C:/Data/Pitt.gdb"
rts = "roads/hwy" #hwy is in the roads feature dataset
rid = "ROUTE1"
pts = "roads/cal_pts" # cal_pts is in the roads feature dataset
mfield = "MEASURE"
radius = "2.5 Meters"
out_fc = "roads/hwy_new" # new feature class in a feature dataset
gp.CalibrateRoutes_lr (rts, rid, pts, rid, mfield, out_fc, "DISTANCE", radius, "BETWEEN", "NO_BEFORE", "NO_AFTER")
except:
# Example 3:
# Calibrate personal geodatabase routes with personal geodatabase points.
try:
gp.Workspace = "C:/Data/Pitt.mdb"
rid = "ROUTE1"
mfield = "MEASURE"
except:
# Example 4:
# Calibrate enterprise geodatabase routes using enterprise geodatabase points.
try:
wkspc = "Database Connections/Connection to Jerry.sde"
gp.Workspace = wkspc
rts = gp.QualifyTableName("hwy", wkspc) # standalone feature class
rid = "ROUTE1"
pts = gp.QualifyTableName("cal_pts", wkspc) # standalone feature class
mfield = "MEASURE"
radius = "5.0 Feet"
out_fc = "hwy_new" #new standalone feature class
gp.CalibrateRoutes_lr (rts, rid, pts, rid, mfield, out_fc, "DISTANCE", radius, "#", "#", "#", "#", "NO_KEEP")
except:
