Overlay Route Events (Linear Referencing) |
Release 9.2
Last modified November 9, 2006 |
Print all topics in : "Tools" |
Overlays two event tables to create an output event table that represents the union or intersection of the input.
Usage tips
Line on line, line on point, point on line, and point on point event overlays can be performed.
The input and overlay events should be based on the same route reference.
If both the input and overlay event properties are type POINT, the output event properties must also be defined as type POINT.
If both the input and overlay event properties are type LINE, the output event properties must also be defined as type LINE.
If either the input or overlay event properties are type POINT, the output event properties must be defined as type POINT when an INTERSECT overlay is performed. The output event properties must be defined as type LINE when a UNION overlay is performed.
If both the input and overlay event properties are type POINT, only the points that have the exact same measure value are considered to intersect. There is no search tolerance.
The input tables can be any type of table ArcGIS supports. The output table can be a dBASE file or a geodatabase table.
An attribute index on the route identifier field speeds up the dynamic segmentation process. If you will be using the Output Route Feature class for dynamic segmentation, it is recommended that you choose to have an attribute index created.
Use Make Table View prior to Overlay Route Events to effectively reduce the number of events that will be processed.
If either the input or overlay events do not have an ObjectID field, use Make Query Table prior to Overlay Route Events to add a virtual ObjectID field.
The output table can be displayed in ArcMap using Make Route Event Layer or the Add Route Events dialog box.
The following environments affect this tool: configKeyword, scratchWorkspace, and workspace.
Command line syntax
An overview of the Command Line window
OverlayRouteEvents_lr <in_table> <in_event_properties> <overlay_table> <overlay_event_properties> <INTERSECT | UNION> <out_table> <out_event_properties> {ZERO | NO_ZERO} {FIELDS | NO_FIELDS} {INDEX | NO_INDEX}
| Parameter | Explanation | Data Type |
| <in_table> |
The input event table. |
Table View |
| <in_event_properties> |
Parameter consisting of the route location fields and the type of events in the input event table. Route Identifier Field — The field containing values that indicate which route each event is along. This field can be numeric or character. Event Type — The type of events in the input event table (POINT or LINE).
From-Measure Field — A field containing measure values. This field must be numeric and is required when the event type is POINT or LINE. To-Measure Field — A field containing measure values. This field must be numeric and is required when the event type is LINE. |
Route Measure Event Properties |
| <overlay_table> |
The overlay event table. |
Table View |
| <overlay_event_properties> |
Parameter consisting of the route location fields and the type of events in the overlay event table. Route Identifier Field — The field containing values that indicate which route each event is along. This field can be numeric or character. Event Type — The type of events in the overlay event table (POINT or LINE).
| <INTERSECT | UNION> |
The type of overlay to be performed.
String |
| <out_table> |
The table to be created. |
Table |
| <out_event_properties> |
Parameter consisting of the route location fields and the type of events that will be written to the output event table. Route Identifier Field — The field that will contain values that indicate which route each event is along. Event Type — The type of events the output event table will contain (POINT or LINE).
From-Measure Field — A field that will contain measure values. Required when the event type is POINT or LINE. To-Measure Field — A field that will contain measure values. Required when the event type is LINE. |
| {ZERO | NO_ZERO} |
Specifies whether to keep zero length line events in the output table. This parameter is only valid when the output event type is LINE.
Boolean |
| {FIELDS | NO_FIELDS} |
Specifies whether all the fields from the input and overlay event tables will be written to the output event table.
Boolean |
| {INDEX | NO_INDEX} |
Specifies whether an attribute index will be created for the route identifier field that is written to the output event table.
Boolean |
Workspace D:\Data\pitt_county OverlayRouteEvents_lr accident.dbf "rkey POINT mile" pavecond.dbf "rkey LINE fmp tmp" INTERSECT accpav.dbf "rkey POINT mile" Workspace D:\Data\pitt_county\Pitt.mdb OverlayRouteEvents_lr pavecond "rkey LINE fmp tmp" pavetype "rkey LINE fmp tmp" "UNION" condtype "rkey LINE fmp tmp" NO_ZERO Workspace D:\Data\pitt_county\Pitt.gdb OverlayRouteEvents_lr pavecond "rkey LINE fmp tmp" pavetype "rkey LINE fmp tmp" "UNION" condtype "rkey LINE fmp tmp" NO_ZERO Workspace "Database Connections\Connection to Jerry.sde" OverlayRouteEvents_lr gdb.accident "rkey POINT mile" gdb.pavecond "rkey LINE fmp tmp" INTERSECT accpav "routekey POINT milepost"
Scripting syntax
About getting started with writing geoprocessing scripts
OverlayRouteEvents_lr (in_table, in_event_properties, overlay_table, overlay_event_properties, overlay_type, out_table, out_event_properties, zero_length_events, in_fields, build_index)
| in_table (Required) |
Table View |
| in_event_properties (Required) |
| overlay_table (Required) |
Table View |
| overlay_event_properties (Required) |
| overlay_type (Required) |
String |
| out_table (Required) |
Table |
| out_event_properties (Required) |
| zero_length_events (Optional) |
Boolean |
| in_fields (Optional) |
Boolean |
| build_index (Optional) |
Boolean |
# Example 1:
# Point-on-line INTERSECT overlay (both tables are dBASE)
import arcgisscripting, constants
gp = arcgisscripting.create()
try:
gp.Workspace = "D:/Data/pitt_county"
in_tbl = "accident.dbf"
in_props = "rkey POINT mile" # reused as out event properties
ov_tbl = "pavecond.dbf"
ov_props = "rkey LINE fmp tmp"
out_tbl = "accpav"
gp.OverlayRouteEvents_lr (in_tbl, in_props, ov_tbl, ov_props, "INTERSECT", out_tbl, in_props)
except:
print gp.GetMessages(2)
# Example 2:
# Line-on-line UNION overlay (both tables are in a file geodatabase)
try:
gp.Workspace = "D:/Data/pitt_county/Pitt.gdb"
in_tbl = "pavecond"
in_props = "rkey LINE fmp tmp" # reused as overlay and out event properties
ov_tbl = "pavetype"
out_tbl = "condtype"
gp.OverlayRouteEvents_lr (in_tbl, in_props, ov_tbl, in_props, "UNION", out_tbl, in_props, "NO_ZERO")
except:
# Example 3:
# Line-on-line UNION overlay (both tables are in a personal geodatabase)
try:
gp.Workspace = "D:/Data/pitt_county/Pitt.mdb"
in_tbl = "pavecond"
ov_tbl = "pavetype"
except:
# Example 4:
# Point-on-line INTERSECT overlay (both tables are in enterprise geodatabase)
try:
wkspc = "Database Connections/Connection to Jerry.sde"
gp.Workspace = wkspc
in_tbl = gp.QualifyTableName("accident", wkspc)
ov_tbl = gp.QualifyTableName("pavecond", wkspc)
out_tbl = "accpav"
out_props = "routekey POINT milepost" # names are changed for out table
gp.OverlayRouteEvents_lr (in_tbl, in_props, ov_tbl, ov_props, "INTERSECT", out_tbl, out_props)
except:
